abit off center
cgarr's Avatar
Take a guess?
Should be an easy one: What is it?
______________________
Craig
G2Performance
Old 12-23-2007, 04:37 PM
Jig for checking valve/piston clearance without assembling the whole top end?
Old 12-23-2007, 05:10 PM
AutoBahned
RWebb's Avatar
twin His & Hers German techno-potties
old man neri's Avatar
Dual christmas tree holder?
Old 12-23-2007, 05:12 PM
Looks a lot like a section of 911 Cam Tower thats modified to attach to that flat steel plate,...
Do I win something cool??????
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-23-2007, 05:26 PM
abit off center
cgarr's Avatar
Bingo!!
I got tired of trying to get consistencies out of the 4 jaw chuck and the home made fixture. There was too much time in setup so I put together this section of cam tower to a face plate which always run true time after time and is perfectly centered. Just take a head off, bolt another on and away you go. These heads just had .004 taken off the sealing surfaces and the repeatability is within .0001, close enough. PAT. PENDING
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Craig
G2Performance
Old 12-23-2007, 05:43 PM
North Coast Cab's Avatar
So what does it do exactly?
1985.5 944 GTS
Old 12-25-2007, 08:23 AM
I'm fairly sure that it alligns the diathrambus, thus making sure it's in sync with the guanocruster
Old 12-25-2007, 08:50 AM
KTL KTL is offline
Schleprock
KTL's Avatar
It's a jig to bolt heads onto for machine work. Saves time setting up the machining process. Now Craig just bolts the head (any head) onto the fixture and it's squared-up every time.
Too bad his fasteners on the face plate are not the same brand and property class- fixture will burst into flames in no time at all..........
Kevin L
'86 Carrera "Larry"
Old 12-25-2007, 09:14 AM
Senior Member
"Saves time" is an understatement here. It would save a lot of setup time and hassle getting it exactly where it needs to be.
Very nice job!
Old 12-25-2007, 09:32 AM
al lkosmal's Avatar
Very nice fixture. Nice work.
RGruppe #669
http://www.x-faktory.com/
Old 12-25-2007, 10:15 AM
I hate freight charges
village idiot's Avatar
Send a message via Yahoo to village idiot
i think you need to check the repeatabilty of the fixture 6 more times by twin plugging my heads for free...........you know, just to be sure:evil:
Tom
78 911SC SC to 73RS imposter SCWDP crew #50 and 51
1969 Camaro "The new project"
Old 12-25-2007, 01:44 PM
Does taking the .004 off increase tre C/R? or is it to remove warping?
Great job with the jig.
79SC driver
77S targa work in progress
Old 12-25-2007, 04:21 PM
abit off center
cgarr's Avatar
The C/R really would not increase much with just .004 but if it did the twin plug hole and chamfer would give it back, plus some. There was slight warping but it really took out the ridge and some pitting.
Craig
G2Performance
Old 12-25-2007, 04:41 PM
