MSD and coil proximity
Anybody think I am flirting with disaster with the coil this close to the 6a?
EDIT: the blue one is going to be removed.. the new coil is red below the MSD 6a.
JP '76 911s Ice Green Metallic bone stock Last edited by calling911; 01-03-2008 at 03:09 PM.. |
Oh and I guess its safe to assume the voltage regulator is not in use since it came out like this when I removed the bolts.. must have on in the alternator?
JP '76 911s Ice Green Metallic bone stock |
Senior Registered User
I was taught to put the coil as close to the dizzy a possible, like over on the fan shoud where you have a very short run from the coil to the center plug of the dizzy.
Randy Jones 1971 911 "Iris"
I hate to move it as I would have to relocate the relay and dont want to do that as it would cause me to work more. ![]() BTW... if those are MSD coils you have them installed incorrectly.. they are not black so they are not the high vibration version.. so you have them installed upside down and you have them in a high vibration environment.. Suggest you get the hi vib coils (part #8222). Call MSD and ask them if you'd like to verify my information is correct.. those are oil filled...
JP '76 911s Ice Green Metallic bone stock Last edited by calling911; 01-03-2008 at 04:05 PM.. |
Dizzy
Because it is easy to type and everyone knows what I mean.
The man that built the motor bought and placed the coils, if he told me to stand on my head and stack marbles to make my motor run better, you would see me with my bottom in the air and a bag of marbles near by. Thank you for your advice. ~RLJ Last edited by RLJ; 01-03-2008 at 04:28 PM.. |
Hmm.. what shall we call an alternator? Took me forever to figure out what a dizzy was.. so I suggest that new members really have no idea what one is... Maybe we should have a pelican translation table .. WUR= Fuel Pressure Regulator etc.. ![]() MSD would disagree with your motor builder.. I'd kinda lean toward the manufacture on this one. This install will not cause your engine to run poorly until one or both fail.. but according to MSD this install will cause premature failure. You're welcome. Anybody have any idea whether I could be creating a problem due to proximity?
JP '76 911s Ice Green Metallic bone stock Last edited by calling911; 01-03-2008 at 05:31 PM.. |
Should be fine. We do this all the time on the racecars.
75 911 Indian Red- RUFWAN2B 2000 Boxster 2000 & 2007 Dobies www.stahlwerks.com Cages and preparation for your Porsche “People who never make mistakes must get tired of doing nothing” Bill : The origin of the orgy of Porsche |
You just made my day! Thanks!! A few more vibration stand off installs and then wire it up and off I go!! thanks again!
I'm w/Duke on this one. I'd use plenty of dielectric for long term. and...... I didn't like the direct path of coil wire to dizzy. It flopped around too much for my taste. So I found out if the coil wire could be lightened. It can. I use the twice as long MSD wire Pelican sells for about $15. You can even mount the coil in the cabin if you had to.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
I bought some raw Moroso wire.. Im building my own cables out of that and some Autolite connectors I am modifying.. when all is said and done I should have just bought a nice set of Clewitts or something for the same price.. I am such a cheap skate. Anyway.. yeah I have a tube of dielectric.. Im addicted to the stuff.. I use it on every connector I can find.. its a sickness.. thanks for the help guys!
I have a similar issue but my coil is the hi-vibration type, my question is posted, about a warning lable on the 6 al box itself. do not use solid core wires.???
1987 911 carrera targa 1969 911 T still working on this one other oldies 1968 honda mini trail 50 ko model free bee came in boxes 1981 CR 250 R basket case rebuilt and running |
Correct.. you must use a wound type.. I frankly do not know what the symptom is with solid core.. I was told you get crosstalk but I am not sure of the source... (the wires actually cause so much EMI that it messes up the MSD box itself)... No race wire I am aware of is solid core..
the magnetic field from one wire jumps into another.
resistor and spiral wire reduce the field.
That's where I have my MSD boxes--two because it's a twin-plug--and my coils. Works fine.
I agree with you about the dizzy silliness. If you can't type get off the pot. LOL, ROFLMAO, IIRC and all the other moronic text-messaging craziness is ridiculous. What really gets me is the people who insist on putting smiley-faces everywhere to say "only kidding," "not serious," "really pisses me," "I'm confused..." Imagine a Shakespeare play filled with smileys to make sure we knew what he meant.
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
LOL.....I know what you mean
..... Just kidding
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
i can't type.
i pound keys.
I have been refering to a distributor as a dizzy long before it took typing class in high school.
I lived in Vancouver BC Canada for a couple of years and they shorten up lots of car part names. They called a radiator the "rad". ~Randy Jones 1971 911 "Iris" |
What kind of air filters are those red ones and where did you get them?
Rob
Air cleaners
They came as a part of the throttle bodies that I bought when we converted from PMO's to fuel injection.
Here is a pic before the red powder coat was applied. ![]() Randy Jones 1971 911 "Iris" |
At least Rad makes a small amount of sense. Dizzy and WUR are pretty (insert word here).
