Porsche80's Avatar
Question How fast should a stock sc be able to go?
Now I know this is an open end question, but what should be the max mph of a stock 1980 SC(not the manufactures data). I got mine up to about 120mph and it would go no faster. My wrench said maybe the rear end or trany gears were changed.
Any thoughts ?
C
1980 911SC
Old 01-04-2008, 07:03 PM
madmmac's Avatar
Were you at redline on the tach?
madmmac AKA Mitch
1984 Factory Turbo Look
2006 4Runner
1998 TRD Supercharged 4Runner (Sleeper)
Old 01-04-2008, 07:09 PM
schoward's Avatar
Are you sure you are getting full throttle? Many stories of throttle rod linkage issues on older cars - out of adjustment, etc.
Old 01-04-2008, 07:10 PM
Danny_Ocean's Avatar
120 ~ 130 sounds about right. 145 for 930's, I think.
Old 01-04-2008, 07:11 PM
Porsche80's Avatar
No redline. Pedal was to floor. Engine just rebuilt completely. Heads ported, new SSI's and performance muffler
C
1980 911SC
Old 01-04-2008, 07:12 PM
the the is offline
138-140
Old 01-04-2008, 07:13 PM
Pool Janitor
I had my bone stock '88 3.2 Cabriolet up to 130 on accident, was only trying to go about 120, but glanced down and the needle was slightly past 130 ish. These Carrera's are not the fastest things off the line, but they go like a demon after 60-70 mph. Car was still pulling really good too! My OM says the car is capable of 149 (Carrera) & 157 for (930). I would be curious my self to know what some of you have hit on a track or closed course
-Ryan
Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body,but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming
"Wow! What a Ride!"
< '88 Porsche Carrera Cabriolet Sold >
Old 01-04-2008, 07:16 PM
madmmac's Avatar
How many miles are on the rebuild?
Agree with the not getting full throttle possibility.
Easy to check, have someone floor it, look in the engine compartment and the throttle opening should just be short of the stop.
SC should be good for 135-140mph.
madmmac AKA Mitch
2006 4Runner
Old 01-04-2008, 07:22 PM
Banned
Stock 2.7 135 mph slight downhill. gets a little iffy about 120.
Brand new toll roads out here in so cal are nice for speed runs.
Old 01-04-2008, 07:27 PM
Detached Member
Hugh R's Avatar
I've read that our speedos are notoriously optimistic by about 10 mph at speed. Mine was according to my GPS, when North Hollywood Speedometer overhauled it, they recalibrated it.
Hugh
Old 01-04-2008, 07:40 PM
UnRegistered User
billybek's Avatar
I have seen + 110 mph also "by accident" and the 83 had a lot of pedal and rpms left.
Still getting to know this car so I can't say for sure.
Bill K.
Old 01-04-2008, 07:49 PM
fitchn's Avatar
120 seems awfully low to me, when my 79 sc was bone stock, smog pump and all, I easily saw 145 on the speedo on a drag strip (used for warmups before a short autocross course) and it didn't feel at all like it was done yet. Still pulling firmly.
Noah
79 SC
minerva blue metallic
Eureka CA / Boulder CO
Physics is like sex, yes there are some practical applications, but that's not why we do it.
Old 01-04-2008, 07:57 PM
UnRegistered User
billybek's Avatar
Does it roll easy? Anything dragging (brakes CVs trans)? Timing, bad fuel etc.......?
Bill K.
Old 01-04-2008, 08:13 PM
Sultan of Sawzall
rouxroux's Avatar
Now if it was only a Targa..........
Gruppe B #319
'66 Monza coupe 110/PG(white)
'95 993 cabriolet (wife's)
Old 01-04-2008, 08:21 PM
gshiwota's Avatar
My '82 SC maxes out at 85 MPH (I still have the original 85MPH speedo).
Old 01-04-2008, 08:38 PM
gshiwota's Avatar
Old 01-04-2008, 08:45 PM
jonbot's Avatar
I had my '79 SC up to 125 the other day, and it didn't feel like it had any ideas of slowing down.
- Everything's easier once you get started. -
'95 993 C2
'73 911 Targa
'88 BMW M3
'84 Mercedes 190e 2.3 16v
Old 01-04-2008, 09:54 PM
PeterRT's Avatar
In period it was tested at 143 mph. If you weren't going uphill into a strong headwind you're probably missing about 70 horses.
Old 01-05-2008, 12:34 AM
my 80sc with stock 3,2 replasement engine does 255km/h on speedo. gps showed 238km/h at the same time, so there is an big gap in actual vs speedo with my small tires. it revs to the limiter in 5th gear with 205/60-15 rear tires. 238km/h equals to about 145 mph. your 120 seems very low indeed. what size tires do you use?
Oh... and my car is narrow body with no rear wing.
Old 01-05-2008, 01:16 AM
Question
120 mph is LOW for an SC. I've hit ~130mph with 1200 left on the tach in 81 Targa (top on of course). Top end in my ride is probably 140mph; not bad for a 27 year old 911SC!
1989 Carrera Coupe (Black / Linen)
1981 911SC Targa (Black / Chocolate)
Old 01-05-2008, 03:30 AM
