Jack Points
Where are the proper jack points for a 85 911?
"O"man(are we in trouble)
its a 944
Rick 88 Cab |
I went back and noticed that.----dense. I didn't think that there would be a 944 or 924 showing up for jack locations on a 911 forum.....
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
Sorry, that's a 944 but since I've done one search I'll leave the next search up to someone else. I was trying to be a good shlt and find it for him. So much for my new years resolution for being a good shlt, back to my old cranky ways.
![]() I'll volunteer the way I lift the rear of my 88 which will bring predictions of doom and gloom. A floor jack with a hockey puck on the pad against the seam of the engine. The front is hard to explain without a picture but a piece of wood between the torsion bar mounts. Someone will answer you.
Rick 88 Cab |
How about this?
2000 Boxster S 1984 Carrera 1976 912E |
![]() A jack under each end of the oak beam, moves front up nice and even. Leaves room for jackstands under the beam right under the jack pads on the car. The rear, I also use the doom & gloom engine case seam to lift, and torsion bar covers for jackstands.
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
"D'ouh!" That looks pretty dang good. Pretty much the same here, except I don't raise it with the engine.
UnRegistered User
There are a ton of good threads with more of this information.
I get kind of lost when I start chasing these things around sometime. I was looking at one thread where a car was lifted on a driveway that looked like pavers but may have been stamped concrete. The jackstands are all correct but using a floor jack on an uneven surface may "pull" the car as it is lifted as the wheels of the jack won't roll. The owner of this car may have placed the jack on plywood or something to prevent this from happening. Is this correctly jacked on axle stands ? Have a quick look through some of the old threads, the info will keep you honest while doing a lift...
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
If you're going to jack at the corners (arrows C and D), be careful not to crush the standing seam. Pelican's jack pad that fits in the slot works good for side-to-side; the engine works good on the rear and the big-wood- timber across the pan works good for the front. Take your time, there's a lot of stuff that can be crushed if you're not careful.
I used to feel bad about providing specific warnings to mechanics ready to jack up my 911, but I got over it. What they DON'T know, in many cases, would fill oceans.
Joe 85 Carrera 64 Honda Dream - for sale 71 Hodaka Super Rat - keeper |
Hi,
Welcome to the Forum. It is expected that you will post pictures. Also, to help us help you better, most of us include our car year and model in our signature line and our location near our user name. This can help us help you better in solving proplems. To answser your question, there are many threads on this topic. IMHO, the best answer is on the Lifting Points thread: Quote:
Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic Last edited by HarryD; 01-09-2008 at 06:06 PM.. |
Lifting one side of the car and putting it on a single jackstand and then trying to lift the other side sounds like inviting disaster.
I don't think jackstands handle side loads very well.
Rick 88 Cab |
UnRegistered User
Still I am not a big fan of lifting by the motor. There is just something about that gives me the willies for some reason. Here is another watch your butt thread. Jack safety...a reminder Go slow, stay safe! (in the garage)
[QUOTE=billybek;3694729]...
Still I am not a big fan of lifting by the motor. There is just something about that gives me the willies for some reason. .....QUOTE] I am with you. Why would you want to lift you car using the single most expensive part as the lifting point?
I've just bought an engine stand and soon will find out for myself.
1982 911 SC coupe RoW moss green SSIs and M&K 2-1 muffler |
It's the way I have always done it and never had a problem, just don't go up too much on one side at a time, lift the sides in stages. I never lift with the motor but have seen and heard of a lot of folks doing that and never known anyone to have a problem.
