Tlook
Guest
Posts: n/a
Question Trans swap problems..help!!
Guys, I've ran into a few snags leaving me puzzled--
When did the 915 change clutch cable style, and why. --Helper spring??--
My 911 had a 73 915 in it, and I neglected to think about swapping the cable out to different style--Nor do I have the bracket that holds the cable to the trans.
Any help is much appreciated......S in Va
Old 03-26-2001, 08:00 AM
john walker's workshop
Guest
Posts: n/a
Post
what year body,and what year trans did you put in it? need more info.
Old 03-26-2001, 08:19 AM
Tlook
Guest
Posts: n/a
Question
71 911e---with 78 915
Old 03-26-2001, 11:20 AM
EdRogers
Guest
Posts: n/a
Post
I'm doing the same thing... I've heard that you can just take the clutch linkage off of your early 915, and add it to the later 915, if you want. I had the option of either when I bought my 915, and I went for the later, since porsche tends to make changes for good reasons. I was told that all I need is a later cable. The side plate was left off of mine when I bought it. That is the reason I am waiting also.
Old 03-26-2001, 11:26 AM
Tlook
Guest
Posts: n/a
Post
Damn! Someone with the same pains kinda makes the pain a little more bearable...I do want to drive this sucker bad though.....
Old 03-26-2001, 11:41 AM
Guest
Posts: n/a
Post
just use the release arm and vertical shaftfrom the 73 trans.
Old 03-26-2001, 01:37 PM
