quick question about lowering my 81 SC
I am trying lower my SC and am a bit confused. Please take a look at the picture for the drive side below. Is the car at the highest height setting or is it at the lowest height setting? In other words, if I turn the adjustment screw counterclockwise, will I be lowering the car or will I raise it higher? If it is at the lowest setting already, i guess I should be able to remove and adjust the location of the torsion bar adjustment lever that fits on the end of the bar?
Thank you for your help.
Old 02-11-2017, 12:33 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Purty much. Just remove and re-index it
'85 Carrera Targa
PCA/POC
Old 02-11-2017, 12:37 PM
back out the bolt, pull the cap off and "reindex" it to a lower position. reinsert and adjust accordingly. you will likely need to adjust alignment, depending on how low you go.
Old 02-11-2017, 12:45 PM
DRACO A5OG's Avatar
also, if your intention is to lower past "Euro" height, consider a bump steer kit. +1 will need to align as lowering will promote negative camber and mess with the toe settings as well.
'85 Carrera Targa
PCA/POC
Old 02-11-2017, 12:48 PM
RETIRED
Joe Bob's Avatar
Also an alignment after you are done....
2012 ML350 3.0 Turbo Diesel
Old 02-11-2017, 01:52 PM
Since none of the above were super clear about it, yeah, that's the lowest you can go without pulling the cap.
Matt - 84 Carrera
Old 02-11-2017, 02:53 PM
Thank you all for your help. Matt thank you for the confirmation.
Old 02-11-2017, 09:03 PM
