While I'm in there...bump steer kit
Hi Pelicans:
'83SC...suspension fully apart...
I took a look, and I don't see the bump steer kit installed (though I do have turbo tie rods, is this curious to anyone?).
Looking for confirmation - I don't know where I'll wind up setting height, but doesn't it make sense to install the kit, regardless? I've never noticed any bump steer issues in the past.
Thanks, Pelicans!
Old 03-11-2017, 10:05 AM
I believe you only need a bump steer kit if you are lowering below Euro height. Otherwise just because you have turbo tie rods doesn't automatically mean you need a bump steer kit.
1989 911 3.2 Targa Guards Red/Cashmere
Old 03-11-2017, 10:15 AM
Bill Verburg's Avatar
Originally Posted by garment View Post
Hi Pelicans:
Thanks, Pelicans!
The most common bump steer kit is the one the places washers between the steering rack and chassis
stock height RoW is 108+/-5mm in front and 16+/-5mm in back
The further below these vales that the car is lowered the more likely you will want at least the washer kit
Bill Verburg
Old 03-11-2017, 10:19 AM
Member 911 Anonymous
DRACO A5OG's Avatar
+3 only if you go lower than Euro height.
'85 Carrera Targa
PCA/POC
Old 03-11-2017, 10:26 AM
Under the radar
Trackrash's Avatar
The only reason you would want to run the Elephant racing style kit is if you raise your spindles. Not sure if that is what you are looking at.
Gordon
'71 911 Coupe 3,0L outlawed
Old 03-11-2017, 11:08 AM
