How often do you rebuild your calipers?
How do you know when to do it? Is there a way to check? Thx
1980 911SC Targa 3.6L |
Friend of Warren
When they leak or stick.
Kurt V No more Porsches, but a revolving number of motorcycles. |
sudo apt-get purge 930
Yup, if it ain't broke don't fix it. There are plenty of other things to do on these cars.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
I have the same question. I noticed for the first time that my calipers are leaking. It was after a race, and the car sat for a long time. I noticed fluid running out on the floor.
I just rebuilt them one year ago. But I guess it's time.
1979 911 SC Silver 2002 996 race car 2005 Ford Excursion |
Racing has a lot of adverse effects on the calipers and the rest of the brake system. Cars that are raced, do need more service on the brake system parts, far more that just a street car. The reasons should be quite obvious, high heat, wear, etc. Street cars can go for a long time before the calipers need servicing. Usually it is only when a failure occurs.
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
I have 83 911. 95K miles on car. Just rebuilt calipers all wheels a few weeks ago. Followed Pelican tech article.
My calipers got stuck from, I believe, lack of use (car sat for awhile). They did not leak. No issues except getting hard lines off without damaging them. Replaced one with a hard line bought locally. Hand bent it to correct shape/configuration. |
Schleprock
Guys in my area with factory sized calipers typically have to reseal the calipers every winter due to cooked dust boots and leaking piston seals by the end of the year. This is a group of fellas who attend around 6 or so track events each year.
While with my bigger brake calipers (and less heat burdening the calipers) I can get away with at least 2 years so far without resealing. We'll see.......
Kevin L '86 Carrera "Larry" |
