Where to get or how to replace plastic rear window on Cab?
I accidently hit my plastic rear window this morning when the plastics was about 0 deg F and it basically shattered.
Now where can I get a replacement back window or even more basic, how do I go about replacing the rear plastic window on my 91 cab?
Charles Navarro President, LN Engineering and Bilt Racing Service http://www.LNengineering.com Home of Nickies, IMS Retrofit, and IMS Solution |
Charles, here you go.
Replacing is possible but definitely not a DIY job. |
Michael Delaney wanna-be
Check out Excellence....numerous top people there too. I don't have the issue in front of me or I'd send you the websites.
88 Carrera Cab C.R.A.P. Gruppe Member #7 |
Used Up User
Somebody mentioned a very good experience with M & T & they seem cheaper than most.
Most of the canvas guys would probably sell them: GAHH, World Upholstery, Cabrioworld And for the record, sewing that area by hand is brutal. I had to repair my zipper seam & a corner of the plastic. Raw, punctured hands & just an OK job were the result. Ian
'87 Carrera Cab ----- “Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.” A. Einstein ----- |
For the record, while I was in GA, I had Atlas Top and Seats (Cleveland, GA) do the rear window and also put a new headliner, all for $525, while I was down there doing oil testing. It's even better than it was before I messed up the rear window now!
Monkey Butt Forespin
Labor to re-sew the zipper only (threads pulled out) on my 84 was $400.
Had I realized he pulled the thing off the car to sew it, I would have bought a new top to put on for that labor. ![]()
Fred Hurder Jr For Tech Questions: '84 911 Carrera Cabriolet (US) Weltmeister Chip, Fabspeed Euro Pre-Muffler, M&K 1-in / 1-out Muffler 22 ERP /29 Sander Hollow T-Bars, Bilstein HD Struts / Sport Shocks ERP Poly-Bronze Bearings (A-Arms & Spring Plates), Stock Swaybars Turbo Tie Rods, '92 C2 5-Spoke wheels w/ 1" adapters, Drilled Zimmermans Yes, I drive mine as much as possible. If it's >32° & sunny, I've got the top down. ![]() |
Thread Tools | |
Rate This Thread | |
