964 Twin Dist. On an SC
I have been told that you can not use a twin plug dist from a 964 on and SC engine.
Why? Thanks!
Jeremy C. Why's he calling me meat? I'm the one driving a Porsche. (Bull Durham) ----Nothing is far away in this car!--- -2001 996 Turbo |
AutoBahned
you can if you modify it
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too Last edited by Racerbvd; 01-20-2008 at 04:51 PM.. |
Irrationally exuberant
The SC distributor turns counter clockwise, the 964 distributor turns clockwise.
So yes, if you took the motor completely apart and replaced the distributor gear on the crank, you could use a 964 distributor. -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
you gonna pick up your boost gauge?
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
Insert Tag Line HERE.....
OR, just install the wires in the opposite direction.
LOL!
![]() -Chris
Senior Registered User
Two points of intrest.
First, the 964 dizzy does not have mechanical spark advance. The SC dizzy does. The guts from the SC mechanical advance has to be installed into the 964 case or some other form of spark advance needs to be used. Second, a sheet metal part is needed to be changed so the new dizzy(distributor) will fit. Don't remember the part number just know it needs to be done, and as was already said the drive gear on the crankshaft needs to be changed. Randy Jones 1971 911 "Iris" w/ converted 964 distributor. |
Could you run the engine backwards??
jp |
Sure could, with some custom cams.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
but why would you not just get the dizzy rebuilt to work correctly or use steves,jbracing ,jerry woods,or supertec's 12 plug dizzy. the jbracing I think being the cheapest @ about 1500 hundred. I don't think anyones else is any cheaper? or any option for that matter other then getting your MSII firing them
abit off center
What about Electromotive? or am I way out of line here.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
still in for what 1200 + ? pretty sure
Megasquirt with dual Ford EDIS controllers. I was able to get the VR sensor, 2 EDIS modules and 2 coil packs for about $20 off of 2 '95 Aerostars at the local U-pick. All you need is a 36-1 wheel and an MS controller. Custom wires are almost the most expensive item unless you can make your own. Runs a very hot spark at >0.040 and with the later EDIS controllers and MS you have the option of lower RPM multispark.
Steve Sapere aude 1983 3.4L 911SC turbo. Sold |
