Guest
Posts: n/a
I'm going to replace my old style head temp sensor ('85 Carrera) this summer. I'd hate to cut the wire in case I need it for a spare, emergency part later.
Has anyone out there removed theirs without using the special, slotted socket? I'd like to know the mm size of the sensor, also. Is there enough room for a crowfoot wrench to do the job? Thanks. regards, jlex. |
Guest
Posts: n/a
old style is 13mm, new is 14mm. i just bought a snap on tool that looks like it will work without cutting the wire. #FRXM14. haven't tried it yet. the old ones have been proven to be problematic, so i would toss it.
Guest
Posts: n/a
Also, the new temp sensor will be two wire
rather than the original one wire. The old sensors depended on their screw threads to provide the ground connection but being of dissimilar metals, they corrode and lose their conductivity. The new one includes a ground wire. George 86 911T |
Throw it on the ground!
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
Make Bruins Great Again
I bought a $3 deep socket and ground a slot using a cutting wheel. It took a little while to get the slot the right size but it worked fine and was a whole lot cheaper than that thing.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
Crude but works great
Jake Often wrong, but never in doubt. '81 911 euro SC (bits & pieces) '03 Carrera 4s '97 LX450 / '85 LeCar / '88 Iltis + a whole bunch of boats |
Member 911 Anonymous
+1 on my Ghetto Tool but I cut/grinded like the previous pic.
Warning it is tighter than a heck and beware you will get alot of cuts. Remember to use a Jack Stand for safety. Break a Leg!
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Large Registered Member
'85 Carrera Coupe, Marble Grey #118 JP/R6 '93 Lexus SC400, '00 Ford F-150 '70 911T- 2.7 (SOLD) |
Nice
Just saved $55! Works great.
Yep, you can make up an entire set, of shop made, deep sensor sockets, for what the cost of just one tool truck socket would cost.
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
You don't need a special tool to get the old one out. Just clip the wire and use a deep socket.
Looks like you made an install tool already. I did the same.
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
