1972_911T's Avatar
Rear heated Window Wires
On the rear window seal there is two internal chanels, one is for the glass to fit in and the other to conceal the wire's how should the wires move from one to the other where they connect to the window? should there be cutouts between the two chanels at this point to allow the wires to go through?
1972 911t RS Styled
G50 conversion underway
1972t Resto Project - http://www.ddk-online.com/phpBB2/viewtopic.php?t=16695
Old 01-23-2008, 02:12 PM
cut holes for the wires. royal pain. i'd rather have a glass shop do it any day. a lot of them are wise to the issue and they won't do it either.
206 637 4071
Old 01-23-2008, 02:18 PM
Senior Member
Superman's Avatar
I've seen this expression before, and I keep thinking "how hard can it be?"
I guess I will find out.
Mocha 1978 911SC. "Coco"
Old 01-23-2008, 02:44 PM
I've done it and it was NOT a fun project. Keeping the wires in the rubber gasket where they belong , before and during the window install is a PITA.
Even the small hole in the package tray where the wires pass through to the engine compartment can be a challenge. It's a tight fit.
You just have to take you time and when it gets ugly, walk away for a while and come back to it in a better frame of mind.
Good luck. You will get it done.
Silver 1980SC Euro coupe
Old 01-23-2008, 03:41 PM
Not fun at all.
Grady aka plain fan
66 912 - enjoying the good life
78 911 SC and 90 C2 turbo look cab - gone but not forgotten
01 996 TT -
09 Audi A4 Avant - daily driver
Old 01-23-2008, 04:09 PM
I had to improvise on the wire install.
Once you're looking at the glass, seal, and wires get creative.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-23-2008, 04:15 PM
Retired Member
Brian 162's Avatar
There's a great thread on this topic from last year. Look under targa glass replacement ( I think).
It shows step by step in regards to the wiring.
80 911 SC sold
17 Tahoe
07 Z06 Corvette
Old 01-23-2008, 06:07 PM
joefrantz's Avatar
As everyone else said, it's a tedious process. You want to cut the holes slightly offset from the contacts so the fasteners and wires remain reasonably parallel to the glass. Once everythig is connected, and tucked into the seal, pull the slack out of the wires so they run in the channel and around the corners without slacking. Too much slack is what causes problems with keeping the wires in the channel. Also, take care to avoid twisting the wires around each other. If they sit parallele in the channel there is less bulk. There will be some crossings where they pass through to the other channel, but other than that, keep them parallel.
Joe Frantz
73 911 T
Old 01-23-2008, 09:29 PM
Senior Member
Superman's Avatar
Old 01-24-2008, 08:06 AM
on rethinking the install.. the frustration was on the wires not leaving enough slack for me to maneuver the glass++. Any time I tried to position the glass wires would pop out of the seal. It was a BFH waiting to happen.
what I did was splice in some new wires to add more room and then in the engine compartment I removed the extra wire and added the connectors.
my ride's not stock anyway so I was just as happy to trash some old wires.
the rest of glass install is routine
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-24-2008, 09:14 AM
kfosburg's Avatar
Send a message via AIM to kfosburg Send a message via Yahoo to kfosburg
I used an exacto to cut out little notches in the flap between the two channels - about 3/16" - for the wires to transition from the glass channel to the wire channel. I made the cut about a 1/2" past where the connector ends. Be careful to not bend the tabs too much because they fatigue break easily - that turned out to be difficult part of my install after one broke and wouldn't take solder very well to repair...
Keeping the stupid outer trim piece from popping out of the channel upon install was much more difficult that running the wires in my case!
Karl
Tangerine 71E
Old 01-24-2008, 10:20 AM
haileypcar's Avatar
Question sort of on topic here: My rear window defrost works fully in 50% of the window (upper) and
about 10% on lower 50% of glass. Any one have any thoughts on a repair. 85 Targa
Old 01-24-2008, 10:26 AM
M
Old 01-24-2008, 10:34 AM
Gertvr's Avatar
Just finished my window install last night and it was by far the biggest PITA of the whole restoration, be prepared to be frustrated.... between the aluminum trim and wires it took the whole evening 5hrs..
Rgrds
Gert
2008 Honda S2000
2003 C4S (Sold)
1975 911 S with some small modifications
"Its good to plan your work, but its even better to do it"
My Gallery
Old 01-24-2008, 10:41 AM
Sorry for awakening an old thread but that is what you get for using the Search function. I just removed my old seal and I assume I need to salvage the old wiring loom but the wires enter the seal through what look like tight fitting holes at the window base so do all of the connectors need to be cut off to remove and new ones crimped on once the old loom has been threaded into the new seal?
1983 Porsche 911SC - Arrow Blue lightweight '74 Carrera look
http://forums.pelicanparts.com/porsche-911-technical-forum/498568-overdue-intro-sc-hotrod-project.html
Old 09-12-2009, 06:36 PM
No one should take a beating for using the search button, even if it's yourself giving the beating .
You do not have to cut off the connectors. You will have to make your own holes in the new seal, and the rubber will be plyable enough to allow the connectors to slip through, one at a time. My old seal had elongated holes, not round, and that's probably the way to go.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 09-13-2009, 08:51 AM
