petrolblue83911's Avatar
removing the front bumper?
How many bolts hold on the front bumper?- 81 sc
-I see the 4 in the front, under the bump strip, where are the others?
-Adam
Old 01-26-2008, 12:43 PM
The rubber bellows at the rear are attached to the bumper on each side in two places. That's all of them.
JR
Old 01-26-2008, 03:25 PM
khamul02's Avatar
Those bellow nuts are very small.
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 01-26-2008, 04:59 PM
Ok-
I've already removed the rubber bellows, and after removing the 4 bolts under the front rub strip I can wiggle the bumper a bit, but it still doesnt seem to want to come off- are their additional nuts adjacent to the front of the bellows I am missing?
Old 01-26-2008, 07:10 PM
khamul02's Avatar
I think that is it. At least that is all there were in my 80. I just giggled it a bit and it slid off the front 4 screws. Maybe check the wires going to your turn signals. Maybe they are hung up. If not that I'm not sure.
Tom Hutchinson
Old 01-26-2008, 08:22 PM
Very funny.
Old 01-26-2008, 09:08 PM
abrumley's Avatar
What about the metal piece in front of the oil cooler in the pass fender well? not sure if your car has it but my 86 does and it was a little pita to get off. you can search for a thread on it's removal if you do in fact have it
Old 01-26-2008, 09:20 PM
the two (10mm I think) bolts holding the valance must be removed from inside the luggage compartment. right in front (or behind) where your jack is mounted.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 01-28-2008, 08:09 PM
