I'm a loser, baby.
oregonmon's Avatar
Quick horn button install question.
On the left is the orginal MOMO horn button I am removing and on the right a Porsche horn button I would like to install.
The MOMO button has two tabs and the Porsche has one. Do I need to remove that tab and put it on the Porsche button? There was the black wire from the column attached to this connection.
Thanks all
1979 911 SC
Old 01-28-2008, 02:55 PM
COL 911
COL 911's Avatar
I just changed my horn button last week and only have one wire to lead connection. Some aftermarket horn buttons I have looked at online have two wires leading from the button assembly, but I'm not certain what the second wire does (always wondered if it was ground, etc.) bottom line is if you have one wire coming through the hub at the steering column, and one lead on the back of the horn button, it should work fine.
Old 01-28-2008, 03:07 PM
I'm a loser, baby.
oregonmon's Avatar
Pretty sure the second one is a ground. So it doesn't need a ground connection?
1979 911 SC
Old 01-28-2008, 03:23 PM
Carrera Cab Connoisseur
nyne11's Avatar
I think you'll find it will need an earth connection. If you look at the small "arrow like" sign it it indicates earth. I replaced mine a while ago and had to have an earth connection for it to work.
Dave
1986 Carrera Wide Body Cabriolet
1993 Nissan 300ZX Twin Turbo (620rwhp)
2003 BMW 330Ci MSport Individual
1973 Mercedes 350 Custom Convertible
Old 01-28-2008, 03:31 PM
COL 911
COL 911's Avatar
Try it with just the one wire and see if it works. The other option is to disassemble the horn button assembly by removing the wire clip, seperating the center button section and spring from the surrounding 'housing', and simply switch the two logo/faceplate portions.
Can you clarify, on the momo you removed, how many wires were running from the column to the button? Did you use two wires with that one, or just one black wire? If just one, I recommend you try a single connection and see how it works.
Old 01-28-2008, 04:00 PM
PCA7GGR's Avatar
The wire loop on the edge of the Porsche horn button should act as the ground when it contacts the steering wheel "hole". Pushing the horn button completes the circuit.
Sergio
The GT Lid Whisperer
PCA 42yrs - National DE Instructor / Ex-RGruppe #197
'19 718 Cayman S (9th Porsche/1st with PDK)
'14 Subaru Forester XT (Porsche support vehicle)
Old 01-28-2008, 04:16 PM
