Insert Tag Line HERE.....
just a tad bit of rust..
battery acid strikes again...
scary stuff here,.. this could have been bad if it broke loose! anybody have a donor car that has a good front tub?? ![]() ![]()
Member 911 Anonymous
Oh My
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
I thought mine was bad...
'70 911T (AKA Bottomless Pit) - Undergoing restoration '13 Audi A4 1.8T - Surprisingly fun means of getting to work |
Impressive! Luckily the front A-arm mount sees very little vertical load ...
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
Mark,
Is this a project car?
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Mitch Leland "03" 996 C2S-LS3 V8-480 HP "84" 911 Turbo Look-Sold w/ found memories |
![]() I would be happy to donate this stool sample, but some ********* cut a hole in the hood.
Ray '88 Carrera, '81 SC, BMW R1200C, BMW R75/5, Ducati S2R Monster, '70 Karmann Ghia |
(the shotguns)
holy effing cow!
i suppose the good news is most of the front pan removal is already done for you! 'course the bad news is there is nothing to weld a replacement pan to......
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
Por 15 will fix that right up...no worries!
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
I goty'er hard drive...right here. ( Yes, the poster is up there next to my George Michael poster)
Did they bring it in because they had a weird "rattle" noise?
1972 911t Sportomatic <----- bet your jealous |
