Slackerous Maximus
HardDrive's Avatar
Replacing front tires without replacing back?
My front tires have worn considerably faster than the back. Tires are Continental ContiSportContact 2. If I have a good 3-4k left in the back tires, is there any reason I can't simply replace the fronts? They are different sizes, so they are sold seperately anyway.
I don't track the car.
2014 Cayman S, PDK
Old 02-04-2008, 08:03 AM
Member 911 Anonymous
DRACO A5OG's Avatar
I did and tracked my baby too. Mine got a nail in the side wall in the rear and I had no choice to replace the two rears to an updated version of the Eagle F1's. No Issues
'85 Carrera Targa
PCA/POC
Old 02-04-2008, 08:12 AM
abit off center
cgarr's Avatar
Makes cents to me
______________________
Craig
G2Performance
Should not be an issue as long as the tires will be the same brand as the rears. If you swap brands, you want to be able to at least match compounds/wear ratings for a compatable grip level.
I'd look into why the fronts are wearing faster. You might check the corner balance of the car and alignment. (unless the rears have already been replaced once and the fronts have been on for the equivalent of 2 sets of rears)
Tony G
2000 Boxster S
Old 02-04-2008, 08:17 AM
Regis turd ab user
First of all were you satisfied with their performance, will you be getting the same tires as your replacing and do they match the rear, ( make and type ). I wouldn't mix.
If it's your daily driver ( what car is this ) and there's only 3K left on the rears, I'd pitch em, lot's more rain comin!
Old 02-04-2008, 08:25 AM
Driver
Noah930's Avatar
I've done the same (change either fronts or rears only). Previous tire was NLA, so I just purchased whatever on the market was as similar as possible compound-/gripwise (like that's ever possible) to try not to upset the balance too much. Even on matching tires, my car (a Turbo) understeers quite a bit, so I tried to select tires that would lessen that tendency.
1990 Black 964 C2 Targa
Old 02-04-2008, 08:27 AM
Shaun @ Tru6's Avatar
You'll want to match speed rating, load index and temp. rating with your existing rears.
Tru6 Restoration & Design
Old 02-04-2008, 08:30 AM
Slackerous Maximus
HardDrive's Avatar
Thanks guys. The tires will be replaced with the same type. It may seem weird to not bother replacing the backs, but I drive the car less than 3000 miles a year, so those backs will easily last me into next year.
2014 Cayman S, PDK
Old 02-04-2008, 09:47 AM
old man neri's Avatar
I would just be careful in the rain. You might get into an ugly situation where the fronts grip but the rears don't, in a turn.
Old 02-04-2008, 11:11 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Mixing and matching brands, treadwear ratings is not critical- car won't burst into flames or crash instantly if you drive it in the rain. Feel the car out and you'll be fine. And fresh fronts, whether they be same type/brand or different, will likely increase front grip (after they break-in) and make the car oversteer. So feel it out
I've run differing brands front-rear on the track (I know you don't track your car) with R compound tires without ill effects. Only reason I mention it is to present an extreme example of using differing brands & grip levels. To take it a step further, a friend (who drives like a stolen car thief) used Bridgestone S-03 front and Toyo RA-1 rears on his car at the track for a 2 day DE event. I was shocked to hear he actually liked the way it handled.
I'd take this as a good opportunity to try another brand of tire if you so choose. If you like them, you can add the rears when they wear out. Definitely look into the front alignment. If your front & rear tires are the same age, the rears should definitely wear faster than the front. Typical 911 rule of thumb is rears last 1/2 as long as fronts.
Kevin L
'86 Carrera "Larry"
Old 02-04-2008, 01:26 PM
I made the same assumption when I responded but then noticed he is driving a Boxster. I am not sure what the wear rate is front to rear on the mid-engine car, but I still think the rears should wear first.
Tony G
2000 Boxster S
Old 02-04-2008, 01:30 PM
Normally the rear wear faster than the front - about twice faster.
I have mixed them w/o problem. Just be sure you go by pairs of the same, both front and/or both rears.
Old 02-04-2008, 01:44 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Thanks for the correction. I did notice the Boxster was the car and the 82 has been sold, but didn't make the connection that I should go back and edit my post.
Kevin L
'86 Carrera "Larry"
Old 02-04-2008, 02:01 PM
3.2 CAB's Avatar
I had a friend that won a Boxster at one of the casinos on the Gulf Coast. We were both finalist in a car key, give away drawing. He got the key that worked, I didn't. Lucky ba$tard!! He owned the car all of 20 minutes, and sold it to one of the New Car Dealers, that were always at the contests. I already had my car, and he already had a new Viper. We both had previously made arrangements with the dealer to sell the car. O-well!!
Back to the topic, I don't think that there would be any real adverse effects, being you are replacing with the same type tires. I would use a little more caution after they are installed, just to make sure that the car still "feels" the same, or if it is grabbing, or pushing through corners or turnouts. A lot of tires that are the "same" tire, except for sizing, the tires have somewhat different "specs" due to the sizing differences. With the mileage that you drive, like myself, the problem is more in the form of dry-rot. I have only driven about 1800 miles, since I had my speedometer/odometer refurbished and re-calibrated in June, 2003. Be careful, and enjoy, your own, "Little Bastard" Good luck!! Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 02-04-2008, 03:21 PM
