Autodidactic user
Yup, it's a supplementary cold start nozzle fitted to the lower portion of the intake stacks. If the enrichment solenoid is operating correctly, this supplementary starting device is activated below 14°. Here is a picture:
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions. ![]() 1973 911E Targa (MFI) Last edited by David E. Clark; 02-10-2008 at 04:00 PM.. Reason: Correct typo |
Max Sluiter
Thanks for the reply.
Since I do not have the heat exchanger hose connection to the enrichment circuit, do I need to block these supplementary injectors off?
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
The cold start enrichtment nozzles in your stacks are actuated by a solenoid on top of your fuel filter. This in turn is controlled by a thermo-time switch that sits in the breather cover on your engine case. It has no relation to the (missing) heat exchanger hose. It is just to help the engine start, after that, during the warm up phase the hot air from the heat exchanger comes into play. This controls the mixture during warm up.
So to answer your question: there is no need to block them
Peter '13 981S '73 911T '05 996 4S cab, now gone '70 911S Targa, now gone |
Autodidactic user
Peter's explanation is correct as is his conclusion that you do not need to block the nozzles. The cold start nozzle just gives an extra squirt of fuel to help start a very cold engine (under 14°). Even though the control rack is set to full enrichment when the engine is cold, the extra bit of fuel from these nozzles helps start a very cold engine. After you've started, the thermostat regulates the mixture up to about 113°. Since you live in Southern California I don't imagine these nozzles really ever come into play for you anyway!
Now if you remove them you might save ½ an ounce each. Think of the performance improvement.
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions. ![]() 1973 911E Targa (MFI) Last edited by David E. Clark; 02-11-2008 at 03:58 PM.. |
Max Sluiter
Thanks David and Peter for your technical explanations. I like learning more about the workings of mechanical fuel injection.
This is an excellent MFI thread, is there another one for CIS?
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
Crusty Conservative
David, great posting, thanks for the leadership here..
Small correction in your second post, third paragraph, you state: The air/fuel mixture ratio is maintained at 14.8 psi Of course you meant to say the ratio is 14.8:1, and the psi slipped in there someway...
Bill 69 911 T Targa, 2.4E w/carbs (1985-2001) 70 911 S Coupe, 2nd owner (1989- 2015) 73 911 T Targa, 3.2 Motronic (2001- ) |
A couple of questions on a fantastic thread...
- I assume the temps are in degrees farenheit, so the cold start temp of 14° is way below freezing, not the balmy temperature of our English summers? - for a '73 MFI setup, as far as I can see there's nothing specific that happens when starting a warm engine, no "warm start" mechanism, no enrichment. Is that correct? Thanks Graham |
Autodidactic user
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions. ![]() 1973 911E Targa (MFI) Last edited by David E. Clark; 02-26-2009 at 06:40 AM.. |
- injection pump (completely out of calibration) - now calibrated - injectors (one completely duff and 5 v poor spray pattern) - new ones to come - throttle bodies (shockingly poor) - to be replaced or refurbed - fuel pressure only a few PSI - to be fixed Hopefully getting that lot sorted will get me properly running and able to start a warm engine without pouring gas down the trumpets! Graham |
Good job. In addition to the MFI resources thread by DEC, this is as good as it gets. I recommended it for the Wiki.
We now ordain you Dr. Injection. |
Recreational User
An awful lot of copyrighted information posted here. I hope this doesn't ruffle up any Pelican feathers.
Autodidactic user
I do not claim to be an expert but I believe that limited use of copyrighted material - like in this and my other posts - is authorized for educational purposes: The Copyright Act of 1976 specifically states: Quote:
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions. ![]() 1973 911E Targa (MFI) |
+1 on the PelicanWiki Great thread!!!!
Mike '99 Isuzu VX, 2005 Audi A4 1.8T Quattro '96 BMW 328ic '73 911T Targa SOLD www.flickr.com/photos/fenderbender813 |
Recreational User
Thanks, really outstanding MFI documentation!
All MFI owners have at least the tools to become true MFI experts (and we need to...) Regards from Prague. Ed |
I think I will raise this from the dead. I've looked at allot of information, but I don't see anything about adjusting the governor? The mixture screw sits on a round plate with four other screws; two silver and two black. Anybody know anything about adjusting these, or baseline settings?
BTW: PacificFI was the last ones into this pump and it looks like they assembled it incorrectly.
james www.gruppe9autowerks.com Its not how fast you go...its how you go fast |
Max Sluiter
Try this thread for the screws: MFI Pump - Open Heart Surgery
What makes you think Pacific put it back together incorrectly? No offense intended, but I trust Gus more than you.
| Tags |
| mfi |
