Member 911 Anonymous
Does anyone know the thread pitch or thread specs of our Infamouse Brake Light Switch?
Is it: 10x1.00 or 10x1.25 Also does anyone know at what PSI our OEM switch activates? 20-50 PSI or 50-100PSI +/-? I have a manufacturer planning on manufacturing a Low Pressure switch for us P-car guys. This may be our solution for the defective design of the OEM brake light switch. TIA
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 02-07-2008 at 03:16 PM.. |
10 X 10.00
I wonder if the problem could be in the master cylinder?
"EVER SINCE EXCUSES WERE INVENTED, EVERYBODY IS PERFECT" http://axiom-motorsports.com/ Rudy Ruano, Operations Manager. Joseph Toliva, guy who signs my check |
10 X 1.0? right? 10MM x 1.0MM pitch?
The problem is the switch, arcing of the current melts the plastic housing causing poor contact over time and more pressure needed to make a good contact for the lights to activate. The low pressure insures less PSI to activate the switch so it will always work. I am trying to see if a Diode can be installed to solve the arcing issue but there is another issue to have enough amps to activate the back up switch II
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
10 X 1.0 is correct.
I thought something was odd when I read it.
Great! Thanks Rudy.
Now i need to put a guage on an OEM switch to find the PSI BTW I need to return the 1/4" spacer, will come by soon. Apparently It will not solve my issue. I need to replace the rear torsion plate bushing at a minimum then re-Camber and Align. Thanks again man!
I have a few switches here, you are welcome to them.
Oh Thanks Rudy, that would be helpfull.
You get the first couple free
