Anything Special About Replacing Horns?
On my 1973.5T I am replacing the two horns (low and high tone trumpet design) this weekend in the left front fender well. With a quick glance last night it looks lime some funky kind of electrical fitting - hook up. It will probably be a piece of cake, but who ever said, working on a Porsche was a "piece of cake"?!
Anyone been there done that?
Bob
73.5T Sepia of course
Old 02-08-2008, 05:49 AM
Porsche Crest
Should just be the standard female to male spade connections. A little tight to work in the fender, job is easier with the front tire removed and car carefully and safely on a jack stand ( don't want to hear about any mishap on Monday). Should only take a 1/2 hour unless the nuts are gummed up with road grim or undercoating.
Regards,
Charles
Charles
1970 911t
1962 356 S90
1964 Safari Rally Comet
Editor www.Bench-Racing.com
Old 02-08-2008, 07:14 AM
Be aware that Hella now gets its "OEM" horns made in China, and they're junk.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 02-08-2008, 07:18 AM
burgermeister's Avatar
If you're replacing just one horn, careful which one you r&r. Only one of mine was working, based on the high pitched sound I figured I needed the low tone horn. I was wrong - I needed the high tone horn, as it turns out ... now I have 2 low tone horns humming their high pitched sound with a slight beat.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 02-08-2008, 09:19 AM
Porsche Crest
Just got a shipment of Hella horns a couple weeks ago. Pulled one out of the box just to verify. MADE IN SPAIN is what is embossed on the horn. No indication anywhere that they are now made in China. Maybe we are getting the last of the old stock? We only have the early style, not the trumpets though. If you give me the Hella part # for the trumpets I can check this out directly with Hella.
Regards,
Charles
Charles
1970 911t
1962 356 S90
Old 02-08-2008, 10:01 AM
sjf911's Avatar
Read the posts on adding a Carrera front oil cooler or the technical article. The horns typically have to be relocated for this project and there are photos inculded. Not a difficult job to work on them. I replaced mine with a $15 hockey puck set to gain clearance for the oil cooler and they work fine.
http://www.pelicanparts.com/techarticles/911_carrera_oil_cooler/911_carrera_oil_cooler.htm
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 02-08-2008, 10:11 AM
I replaced the ones on my SC with WOLO dual trumpet horns. They were the same size as the originals, used the same mounting too.
John Adams
1980 ROW 911SC
Old 02-08-2008, 10:42 AM
Appreciate the responses.
I found a pair of "working" OEM trumpet horns (hign low tone) made for early 911's on ebay a few months ago, so I bought them. My horns work, but with the trumpet portion broke on both, it sounds more now like I am choking a duck!!
Bob
Old 02-08-2008, 11:11 AM
