Boogs on low rpm acceleration, Help
I have webers on my 70 T (S pistons, Cylinders, E cam). When I push the throttle hard before the r's reach 3,000, the car boogs for a moment. Is this a sign that the main jets are too large? Or maybe the venturis?
Thanks in advance,
Robo
356robo
70 T Targa
Looking for a 2.2,2.4, or 89 coupe
Old 02-16-2008, 08:27 AM
Loose nut bhind the wheel
Need more information. Has it always done this or is it recent. What is the state of tune. More description and you will probably get lots of help here. Also you might do a search of the forum.
Ed
1970 911S Targa 2.7RS MFI dual plug 10.5:1
1974 260Z SCCA ITS
1998 M3
Old 02-16-2008, 08:34 AM
Engine and carbs rebuilt about 6,000 miles ago. Always had the boog. The webers are 40's with 30mm venturi, 135 mains, airs are 180, 55 idles. Timing and plugs 1000 miles ago, value adj 100 miles.
Robo
356robo
70 T Targa
Old 02-16-2008, 08:48 AM
I don't know Weber's but someone should chime in. I'll give you a bump but change the title from "boogs" which should be bogs to "Hesitates on low RPM acceleration, weber carbs help please".
Ed
1974 260Z SCCA ITS
1998 M3
Old 02-16-2008, 06:47 PM
Evolved
Mo_Gearhead's Avatar
Sounds like it could be an accelerator pump problem?
If mis-adjusted, the pump(s) may be supplying either too much fuel at transition ...or not enough?
Don't fear the reaper.
Old 02-17-2008, 04:55 AM
