Guest
Posts: n/a
I'm planning on going down to the local auto-body place and getting some guards red paint for a little project. I need to know the paint code for my car (87' 911) does anyone know it?
Should I ask the shop to thin the paint, or do it myself? Thanks :-) ------------------ Dan Tolley 1987 911 Coupe http://www.cheaterswayside.com/911/gallery.asp?sort=0&userid=294 |
Guest
Posts: n/a
if things haven't changed since 74, you should have a metal placard on the drivers side door frame(forward on the hinge side) that gives the paint code for your car.
------------------ Dan S. 1974 911 Targa |
Guest
Posts: n/a
911 095 932 20 80K
80K is the code color for guards red. GB83SC |
Guest
Posts: n/a
depending on who mixes it, you will get one of forty different colors of guards red with the same code. gotta be the worst color to match.
Guest
Posts: n/a
Have them match it to the car, not the code |
Guest
Posts: n/a
Great, such positive responses :-) I realize the paint code is on the side of the drivers side door frame. Unfortunately much of that sticker is worn/ripped off. I didn't want just part of the paint code.
I'm painting a rear lower valance that will accommodate my dual outlet exhaust. The color does not have to be as perfect as if it were the hood. I will however, heed the advice given by JW's Workshop and bring the car in to match the paint. Is there any specific brand of paint I should ask for? I should most likely ask for a primer and clear coat at the same time, right? Thanks again, ------------------ Dan Tolley 1987 911 Coupe http://www.cheaterswayside.com/911/gallery.asp?sort=0&userid=294 |
Guest
Posts: n/a
Dan, definitely have the colour matched to the car. A good paint shop should have no problem with this. I don't think you'll need a clear coat on top of the red, but check with the paint shop and be guided with their knowledge.
Cheers ------------------ John Forcier 69 911T |
