supercarrera82's Avatar
Window doesnt go back up?!?!?!
I have a 1982 porsche 911 sc (automatic windows), the other day i was driving home and put the windows down, the drivers window works fine , but when i tried to put the passenger window back up it wouldnt go back up, only down, to a point where the window is all the way down now. I figured one of the wires on the window switches on the door might have disconnected, so i checked and they all looked good. Tried it again and they still would not go down......Any ideas? Thanks
Old 02-19-2008, 05:19 PM
Driver
Noah930's Avatar
What happens when you reach across and use the switch on the passenger door?
1990 Black 964 C2 Targa
Old 02-19-2008, 05:35 PM
I've experienced the very same thing on my 80 SC.... The window switches for the SC's are noted for their failure rate. Try using the pax side switch. If no-joy - time to buy a new switch. Switch removal is esay > use a 2" sheet rock "mud" spreader - pry the switch out - switch out the wires [after noting the wire configuration].
Good luck
Kim Langley
2012 Carrera / 991.1
80 911SC
97 C230
73 BMW 2002Tii
Old 02-19-2008, 05:58 PM
if i use the passenger side door switch it does the same thing it goes down, but not up, same with the driver side switch for the passenger window. so which switch doesnt work then, the switch on the passenger door or the switch on the drivers door for the passenger window?
Old 02-19-2008, 06:03 PM
Make Bruins Great Again
Por_sha911's Avatar
Are you sure that the window isn't off the cradle? If it is, you will hear the motor running but nothing is moving.
Joe
Old 02-19-2008, 08:51 PM
I have had this happen before. In my case, I kept working the switch and eventually got the window to roll up. It bought me some time until I could get the switch replaced.
JR
Old 02-20-2008, 04:58 AM
The drivers side window is electriclly connected to the passneger side. So it makes sense it wouldn't work either. If it's the same as my 84' the drivers side has 6, I think, wires. The center two, (striped) are the motor wires. Maybe one came off. Switch them to get the window back up.
O2 In Sully We Believe
Old 02-20-2008, 05:46 AM
Power Window Switch schematic
Check out the second drawing, the complete circuit. Notice the drivers door, passenger window switch. If one of the connections to terminals 3 or 5 is bad then you will have one way operation.
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 02-20-2008, 06:31 AM
