Error Codes for a 996
I recently drove my 996 triptronic to the gas station and filled it up. When I attempted to start my car it was dead. After towing it to my mechanic the fault codes were as follows... P0740 & P1770. What could have caused this? I know what they mean but are there any fixes for the problem. I crawled to the station and it was in drive not using the shifting mechanism.
Thank you for any suggestions.
Old 02-18-2008, 05:37 PM
efhughes3's Avatar
Wrong forum....
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 02-18-2008, 05:49 PM
911quest's Avatar
P0740 is Torque converter clutch fault...possible bad torque converter
P1770 is a manufacture specific code that I don't have any info on but it has to do with the transmission
Tony Proasi
1969S
1957 VW Pickup
Old 02-18-2008, 05:59 PM
jwetering's Avatar
Originally Posted by efhughes3 View Post
Wrong forum....
+1
get thee over to rennlist or 6speedonline
jasper
2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car.
past: another 2002 996 and a 1978 SC with-webers-cams-etc.
Old 02-18-2008, 06:10 PM
DW SD's Avatar
It seems that both errors relate to the transmission. AND...it seems that likely one issue, IE one sensor fault would trigger both codes. Did anything happen at the gas station that is unusual?
Maybe a better idea of the order of events would help? When did you "crawl" and when did you drive? What sequence? What do you mean by "dead"?
I have to laugh! I am guilty, too. Imagine a foreigner reading the description with limited knowledge of slang English? They would definitely get the wrong idea.
Let us know more info. I suspect it is something minor, but am no expert.
Doug
1971 RSR - interpretation
Old 02-18-2008, 06:12 PM
