where is the engine number?
Hi,
I have just checked under my car and found a number on the gearbox 73d0888, but according to my log book, my engine number should be 63d0905? so i am just wondering, am i looking at the wrong number, i can't find any other similar number on teh engine, except the large one beginning with 930 on each side of the engine, but this one is nothing like what i am looking for? If 73do888 is the engine number, what type of engine is it, as it seems to be a later number than the last SC? kind regards j
1982 911 SC 'Paloma' 1989 Mercedes W124 250DT (inferior substitute for the U-boat) 1998 Honda CBR900 RRW, (gone but not forgotten). 1982 VW Scirocco 'Roger', (took my youthful abuse with complete aplomb) 1969 Daimler 420 'Agatha' (why did i ever sell the old girl?) |
Friend of Warren
go back to you engine and look at the fan housing. Go to around the 3 o'clock position on the fan housing. If you look down the side of the housing to the engine you will find a flat vertical spot on the engine housing with the engine number.
Kurt V No more Porsches, but a revolving number of motorcycles. |
many thanks,
good news, it is the correct one! phew
On the right side of the fan, look at the lower right corner. The engine number is on the side of the block (not engine fan shroud) and runs vertically. Also, just behind that on the flat part of the engine is the engine type number. You may need a flashlight and a rag with some cleaner to clearly see the engine type number.
Tony G 2000 Boxster S |
