Installing rear light unit wires - looking for a trick
I'm reinstalling one of my rear light units, after replacing the wire harness for the light unit with a new one from Porsche. The female plug that goes through the inner wheel house, into the engine bay, is stiff, stiff, stiff.
Has anyone got a trick for making this job easy? Many thanks. Last edited by Tom F2; 02-23-2008 at 06:56 PM.. |
The best I could ever do was clean it really well, and lube it up with a decent rubber treatment. Then seat the groove of the rubber plug into as much of the lip of the metal hole as possible & work the rest through carefully with a flat blade screwdriver.
Good luck.
Marv Evans '69 911E |
Heat the rubber with a heat gun on low heat. Test first on some old rubber, so that it do not damage the rubber. The rubber will be a LOT SOFTER WHEN HEATED, BUT GETS STIFF AGAIN VERY QUICKLY WHEN IT GETS COLD AGAIN, SO YOU HAVE TO BE QUICK. i SEAT IT AT ONE EDGE AND PRESS THE REST OF THE EDGE IN WITH A SCREWDRIVER, OR OTHER TOOL. Sorry for the caps, did not see until now.
John
997 C2S 2005 "Slate grey"(special order 1965color) 911 SC 1978 Silver/black 34.000 miles from new! 911 2.2 S 1971 Albert Blue/Black and 911 2.2 T 1971 Tangerine/Blood Orange/Black Sold: 911 2.4 S 1973 Viper Green/Kelly Green; 993 C4S 1996 Black/black; 993 C4 1994 Black/Black; 996 C4 2000 Black/Black; 996 Turbo 2003 Silver/Black |
