Student of the obvious
LeeH's Avatar
Odd lumpy wear on outer edge of RA1s
Anybody ever experience this? There is a lumpiness to the outer edge of my RA1s. They are definitely at the end of their useful life... at my last autocross the rear got very loose. When I got home I noticed that the left side had a $.25 size chunk missing where the cord is now showing. The tires have had this wear pattern for a while and on both sides of the rear. I crossed them (ie dismounted/remounted) left to right and got the same results on the "new" outer edge. I can't really figure out what would cause the uniform high and low spots. Any ideas?
Lee
Old 02-23-2008, 08:28 PM
Smart quod bastardus
fredmeister's Avatar
I have experienced this too. I think it is a sign that the tires are used up. It is probably related to the belt construction.....but the fact that you see cords means stop using them. How much toe in are you running, as that may be a cause too. I am no tire expert, but I have seen this happen to me.
I had just started seeing cords less than the size of a dime on one tire at the end of a DE weekend. All I did was drive home 250 miles on them and it opened up to the size of a half dollar......lucky to make it home.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 02-23-2008, 09:24 PM
Administrator
Jack Olsen's Avatar
How old are your shocks?
Old 02-23-2008, 11:34 PM
J Smith's Avatar
Normal for RA1's.
Josh
'87 911 Carrera 3.2 Coupe
Old 02-24-2008, 12:09 AM
MBruns for President
JeremyD's Avatar
Yep - normal for RA1's - that's the sign that you need new tires.
Old 02-24-2008, 07:33 AM
LeeH's Avatar
Not very old at all, but are KYBs installed by PO.
Lee
Old 02-24-2008, 07:38 AM
DUK DUK is offline
DUK's Avatar
Delamination, Tire is done.
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 02-24-2008, 07:51 AM
LeeH's Avatar
What's odd about this is that it started when the tires had plenty of rubber left. Once I swapped the tires on the wheels, the former outside edge smoothed out and the new outside edge got lumpy.
Lee
Old 02-24-2008, 09:21 AM
Check your toe in settings.....this may be causing this.
My theory is that the tires are scuffing from too much negative toe.
As long as the tires stick, why worry? But it does look like those tires are worn out anyway.
Old 02-24-2008, 05:16 PM
Diss Member
Quicksilver's Avatar
That is a classic sign of shocks and tire balance.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 02-24-2008, 05:59 PM
once they get past bald they start to regenerate new tread
Old 02-24-2008, 06:08 PM
LeeH's Avatar
Rogaine for tires??? That's what we need!
Lee
Old 02-25-2008, 12:36 PM
