Guest
Posts: n/a
a/c expansion valve-Where is it?
I want to replace the expansion valve as I'm sure my problem is a dead restriction (ie. x-valve seized up). I can't locate it on my 85 carrera. Any one know how to access it? I know it should be next to the evaporator but I don't want to start tearing everything apart to find it.
Guest
Posts: n/a
I think this is a disk shaped valve located on the A/C unit that is under the trap door in your luggage compartment.
Nick ------------------ _ _ __ _ _ Nick Shumaker 1982 911SC Coupe nickshu@yahoo.com PCA -- Rocky Mtn. Region |
Guest
Posts: n/a
Thats a fact Jack! or should I say Nick
Guest
Posts: n/a
You may have a blocked filter/dryer. I was having a problem with my head pressure and found out that the filter/dryer was the culprut. It was in the car since 78. You might want to check it first.
The expansion vlave is located in the front under the plastic cover, below the trap door. It is disc shaped with a capilary tube attached. Steve |
Thread Tools | |
Rate This Thread | |
