Free.
Can't hurt (like chicken soup) MAY actually lower oil temp. AND Looks "cooler" than a straight old filter wall. Use it, and practise dropping comments like,"Oh....YOURS doesn't HAVE the Super Jet Portable Oil Heat Removal system???" This approach will work exceedingly well on the ultra purists (usually driving a Buick) who will happily point out that you have an uneven number of rivets on the brace for the battery box or that your lug nuts aren't tightened symetrically with the faces equally spaced. I recently offended one such who commented he could NEVER drive a Porsche which had desecrating FERARRI yeller paint on it. He would really be offended if he discovered Ferarri giallo fly yellow was indistinguishable from Yellow Cab yellow;-). TO simply remove and discard would be akin to dumping your Barney Knob. Last edited by dickepoohp; 03-03-2008 at 05:35 PM.. |
After learning about getting your oil up to temperature and keeping it there for prolonged periods, I'd say you'd be better off without the thing for two reasons:
1. Excessive wear is caused by sluggish / cold oil, and 2. Mayonnaise (acidic compounds and gunky sludge) can apparently build up in your oil if you don't keep the engine at temp for long periods (depending on how many miles you drive it at a time.) Check out this thread: Oil Change - 80 911SC Let's not forget that there's a thermostat inside the right rear wheel well that only sends oil up to the front cooler / heat exchanger after it reaches about 113 deg F (Bentley 911 Carrera 84-89 Service Manual, pg 170-4). This is so that the oil heats up relatively quickly to reduce wear on engine components. I've always thought that installing an oil preheater would be a good idea. Owners of small piston airplanes in cold climates use electric & propane preheater blowers for their flat-6 engines. It'll take my car 5 miles or more to stabilize at "operating temperature," and I suspect that over the long haul a good portion of wear within an engine occurs right after startup. So I would recommend NOT using something that took additional heat out of the oil potentially too soon. How much difference will it make? Probably not much, but then again, we're quibbling over the fun nitty gritty details, right?
Craig C '87 Carrera Red/Tan '81 Coupe Red/Tan (fond memories - she was my first) '55 550 Spyder (in my dreams) |
This time of year, I can just toss one in the snow, and it will be good and snow cold in a few minutes, no cool collar needed.
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
Habitual User
If I walked by your car and saw that I wouldn't say anything about it but I'd chuckle to myself.
![]() '80 911 Targa |
I have one and I like it.
Gary H 1978 911 SC
A heat sink (or heatsink) is an environment or object that absorbs and dissipates heat from another object using thermal contact (either direct or radiant). Heat sinks are used in a wide range of applications wherever efficient heat dissipation is required; major examples include refrigeration, heat engines and cooling electronic devices.
Everyone is using a heat sink like it or not. The question is does it displace enough heat to help save an engine. On my F250 that pulls a 11k lb. trailer sitting in direct air flow I have seen a decrease in oil temp. On my SC it was null. |
But for this car... 40-110F max on top of the shroud, and possibly higher after a hard drive
Senior Advisor
add a couple magnets and then your on to something
08 Cayenne Turbo |
Caveman Hammer Mechanic
I would install it just to issue noogies, without even trying!
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
The factory tried this .
What about fins around the oil tank? I guess the factory thought of that too , but then again .... they knew what they were doing!
'81 924 , '85 944 , '78 911SC , '82 928 5.0L "They run best being run close to the ‘limit’ and done so regularly" - Grady |
. Besides...I'm a firm believer in dropping weight on my fat Carrera pig, so she's been on a diet...that .5 oz hanging on the rear would have been the first thing to go! Besides...it might get your car all out of balance....
Undocumented User
Does it also add horsepower?
