RichF's Avatar
Tune up sequence???
Here are somethings I'm going to be doing in about a week and wanted to know if this looks like the right order, so everything gets adjusted correctly.
1.) Trans. and oil change (Swepco and Brad Pen)
2.) Check Valves and/or adjustment
3.) Check Timing and/or adjustment
4.) Tune Carbs
"Work harder........... Millions on welfare depend on you"
" If you aint cheaten you aint tryin"
Old 03-10-2008, 05:05 AM
Job Sequence.....
Rich,
Perform the valve adjustment before changing your motor oil. Clean well the mating surfaces of the lower valve covers and seal them good to minimize oil leaks. HTH.
Tony
Old 03-10-2008, 07:43 AM
RichF's Avatar
why wait on the oil change?
Old 03-10-2008, 01:47 PM
AutoBahned
RWebb's Avatar
easier to do it when you drain the oil
try it some time w/o draining....
Old 03-10-2008, 02:05 PM
Job Sequence.....
Or drain the oil and do the valve adjustment. Your sequence #1 says oil change and then #2 do valve adjustment. Drain oil and adjust valve followed later with oil fill. Does this makes sense? Unless you meant by 'oil change' is drain oil.
Tony
Old 03-11-2008, 06:01 PM
