GotaT's Avatar
Send a message via AIM to GotaT Send a message via Yahoo to GotaT
Exhaust Sealant - Wurth?
What is the best sealant to use on the Exhaust Gaskets? I have some Wurth product that Pelican sells and wonder if this works well. Can this also be used on the Intake side of the Heads?
Old 03-10-2008, 09:29 AM
DW SD's Avatar
I haven't used sealants for either exhaust or intake, just the factory gaskets.
I am no expert.
Doug
1971 RSR - interpretation
Old 03-10-2008, 09:37 AM
Slumlord
Porsche_monkey's Avatar
You shouldn't need a sealant, in my opinion. And I don't think it will work long term.
You might consider making some gaskets out of copper sheet, if you have some angular contact that might help seal it.
Old 03-10-2008, 09:40 AM
I have had success with copper spray
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 03-10-2008, 11:42 AM
Somatic Negative Optimist
Gunter's Avatar
I have used a high-temp anti-seize lube called Neverseize on BOTH sides of the gaskets.
In fact, I use that on all gaskets like the sump or valve covers. Both sides; it prevents the gaskets from sticking.
For the muffler, I smear some muffler cement on both sides of the copper gaskets.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 03-10-2008, 12:00 PM
911 carrera 3.2 (1985)
kees's Avatar
My Porsche dealer recommended Walker Exhaust Jointing Paste (made in Germany).
Kees.
Old 03-10-2008, 03:07 PM
GotaT's Avatar
So then, what does this wurth product do?
Have you used Antisieze on the Studs?
Old 03-10-2008, 04:39 PM
Jeff Alton's Avatar
The exhaust should seal fine without any "sealant" required.
Cheers
www.turn3autosport.com
Old 03-10-2008, 06:17 PM
Antisieze yes, and the Wurth stuff could be good when reusing reusing old pitted squished and compromised exhaust gaskets.
It will help if the gaskets aren't available but it has to go back together.
Old 03-10-2008, 10:37 PM
