'73 911 RSR Optimal Track Tire Sizing
Gentlemen! Been a while since I've been 'round these parts, but I know this is the center of the universe when it comes to RSR Clones. I'm facing the standard dilemma that most that go this way ultimately do, namely getting the appropriate wheel/tire combo. I did some searching but I failed to find any real answers.
Okay first the facts. The car in question is a track only 1970 tub, full erp/coilovers all around. Target weight is 1900-1950. Body work by Getty Design. Power is by 3.2 Autronic producing somewhere around 270-280 at the crank. Full cage, ultra stiff. 450/600 springs at the moment. Manual everything of course, no brake boost, power steering etc. Classically one would go with a 275/315/17 combo, but my understanding, and reviewing the old threads around Jack Olsen's build seems to confirm, that the 275s can be problematic up front. Being into hassle avoidance and somewhat of a contrarian, I'm considering going up to 18"s and running 255/35F 295/30R on 9s and 11s. One considerations is that when it comes to tires is that I'm cheap and want to be able to have one set of R888s or NT01s available. If I stick with 17s this largely seems to limit me to 245/275 or 275/315 if I wish to risk fitment problems. Another consideration is that for when I get serious, and add a second set of wheels and tires, the prospect of running GT3 Michelin Race Rubber 240/280-18s has some appeal not to mention that as a 997 CUP weighs quite a bit more than do I, if its good enough for them, what benefit is there to going larger than that? If I were to stay with 17s I expect my race tires strategy would fall back to Hoosiers and again its a 245/295 setup versus a 275/315 setup. So with all that running around in my tired confused cranium, it really boils down to a question that Jack asked ten years ago on these pages, which is when is enough enough. For those with real track experience with RSR clones or 911s of equivalent weight and performance, the question is what are you sizes are you running and is it too little, too much or enough. Given my car will have maybe 700#s on the nose are 275s too much to wrestle with? Is some form of 245/275 or 315 combo more ideal that the 275s up front? Would lower profiles of 18s really be worth the extra cost. If the 275s really are worth it, how much hassle was involved in getting them to fit? I guess I could put it another way. For those running 275/315|335 do you truly get your tires up to temp and how much better where your lap times? Got to get this done soon, so any advice/experiences is greatly appreciated!
Tailwagger NER/NCR PCA, SCCA, NASA, COM 2000 996 C2 Aero Brumos 59 Special Ed. 1970 911 3.2L RSR |
newb.
more pictures.
keith '75 RS/RSR-look | '73 CB750 | '70 TD250B r gruppe #436 |
Hmmm you think that would help?
Not sure what you want to see, but okay, I'm nothing, if not accommodating. We're a bit further along than this, these are the latest photos I have. Threw in one of the rear suspension just to wow you a little... ![]() ![]() ![]() ![]()
Hmmm... I can understand no facts, but no opinions? I have been a way for a long time.
With 280 crank h.p. I would stay around 225/245 fronts and 275 rears, 16's or 17's. The bigger the tires the more h.p. & torque it takes to turn them. On our '75 rsr look w/3.4 325 h.p. I run 245's front & 295 rears. Just my .02
Administrator
I've run 275/315 and 255/275, with similar HP to you but more weight. Oddly, my best lap times have been with the 255/275 combo. I can't say conclusively that the narrower tires are faster on my car -- too many other changes, and no same-day comparisons, yet. But it's something to consider.
I had trouble fitting 275's in front because I have front flares that are one inch narrower than standard turbo flares. Although I've heard of Turbo guys having problems getting more than 255 mm tires in there. That might have more to do with wheel offset than available space, though.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Friends of Warren
I used to have the 275/315 combo under turbo flares but when we switched to coil overs the 275 would not fit in the front anymore and had to go with 255/315.
Thanks guys. That was some of what I'd been hearing from my hot shoe racer friends that narrow up front seems to be better. I was hoping your real world experience would confirm this. This seems to be the last piece in the puzzle, so I think I've pretty much made up my mind to go 18" despite the somewhat staggering cost differential with 17s. R888s in 255/35/18x9.5 295/30/18x11, at least to start. Friend of mine is good friends with the team boss for one of the top ALMS teams. When I contacted him, he couldnt give much advice as to size as they dont deal with early cars, but hes adamant that whatever I do, go 18". As an added bonus, in these sizes, I can pick up some free + shipping scrubs from them too! I guess I simply recall how much faster in the corners a GT3 Cup is than my current 225/245 setup and if they can do that on 240/280s with an extra 500#s, I'm thinking I should be pretty good.
Thanks guys! (BTW Jack, RJay = Tailwagger)
Obviously you were making some substantial suspension changes at the same time, so perhaps this is a stupid or impossible question to answer, but did you notice any change you might atribute to the change in size? Crisper turn in perhaps or more understeer at track out, etc?
Friends of Warren
RJay
I went from your typical T-bar stock set up to the ERP 935 kit plus the smart racing camber boxes welded on the strut towers. The car is insanely more responsive now (to the point that I needed to add some toe in) but I am afraid the tires are just one of the variables that were changed. I am sorry I cannot be of more help. |
Jack - are your front flares considered 'normal' RSR flares or are they purely custom flares? I've been wondering for awhile now if early front RSR flares are a bit narrower than later front turbo flares. Thanks for the help! -Scott (Currently running 245/45-16 fronts on 9x16 Fuchs and 275/40-17 rears on 11x17 Lindseys. Soon I'll swapping the fronts to 235/40-17 on 9x17 TruDesign Fuchs). |
The photo below is with a friends 255/18 ( i think its a 35) rear tire off a narrow body with a spacer pushing the rim out. (dont know offhand the spacer width). I think I could manage the 275 from this photo (these are the latest Getty Design flares) but again, I think other considerations say that 275 in front is probably not optimal anyway. I'm hoping that gaining the track width, but staying a tad narrower will actually give me an advantage over a friend of my friends who've perhaps subscribed blindly to the bigger is better theory.
Administrator
My flares (and my whole front suspension configuration) are custom. I don't know if the original RSR width was significantly different than the Turbo's.
When we got rid of the front coils to make room for 275s, there was some 'clearancing' that had to be done due to overall tire height. Some patience and a BFH were the essential tools.
Figured I'd wrap this up for future generations looking for an answer as to what sizes fit a fairly standard RSR conversion. Again the particulars probably cause a certain level of variance in this, but with a 1970 tub, erp coilover suspension, standard raised spindles, Getty Design body, we easily fit 255s in front and 315s in back. Wheels are 9.5x17F and 11.5x17R. If I'm remembering correctly its a 6" backspace in front and 5.5" in the rear. There appears to be enough room to accommodate 275/335 combo. If expect that once I scape together the $$$ for a second set of wheels and tires, I'll be trying that setup as well. Heres a couple of photos with the 255/315s (no engine in and prior to any setup). Thanks for the advice everyone.
abcdefghijklmnopqrstuvwxy
Two words. . . .Black Primer. I look forward to seeing the (mostly) finished product.
Jay 2010 Spec Iron Mustang NASA GLD #113 (sold)1981 SC Coupe 3.6 (in '74 Carrera clothes) (sold)1999 Spec Miata NASA GLD #113 jaynorthauto.com |
Its been a long, long road, the car and I recently crossed our tenth anniversary together, but I figured I'd revive this thread to document latest disposition of the car. I've run it in raw glass for the past two years, won a race or two, broke a minute at LRP and finally decided that this would be the year to actually make the car look as good as it goes. Here are a couple of photos of the down to bare metal redone shell with graphics. As the build progresses I'll add a few more. Many, years, many $$$, but much, much love. Truly dig that shaved roof line.
Very nice.
So, what tire combination did you settle on?
Bob F. 1984 Carrera Factory Turbo-Look |
Very nice, I like!!!
Brent Christchurch, New Zealand. Project: 1973 RSR Clone build http://forums.pelicanparts.com/porsche-911-technical-forum/576125-nz-73-rsr-clone-build.html |
Thanks! Actually, I mentioned that above. 255s in front and 315s in back. Wheels are 9.5x17F and 11.5x17R. Since then I've added a set of 9 & 11.5 18s. Looking to pick up one more set of 17s this year. Probably 9s in front to be able to run 710s at some point.
I think what the past couple of years have taught me is that at my HP and weight level, running a harder compound tire like a r888, 315 is indeed too wide. Even driving flat sideways, the rears just never fully get hot enough. Hoosiers OTOH, have no problem at all coming up to snuff. If I were just DE'ing and running Toyos for longevity I'd probably run 255/275. OTOH, for enduros the wider hard compound tires can run all day long. For sprints, the 255/295 or 315 Hoosier setup has proven to be very good.
