SCWDP911's Avatar
Kind of like Car Guru was saying, I have to admit that I much prefer the looks of the coupe if compared to a cab when the top is up. I only like the cab looks when the top is down. but then I guess that is the way it should be in the universe, right?
Shane
- 1984 928S
Old 03-22-2008, 08:11 AM
3.2 CAB's Avatar
mack6820, why don't you just add the additional snaps to you boot. Don't bother to remove to one already there. Just add what you need that will match the snaps on your frame? They don't cost much, and it would make sure that it was not blowing around.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 03-22-2008, 10:47 AM
mack6820's Avatar
I will when I have time. Just havent bothered with it yet. Been driving it without the cover for 2 years, no problems.
Certified Southern Dumbass!
83 911SC with 993 conversion,
98 Ford Expedition 4WD lifted beast, 98 Jeep Grand Cherokee, 01 Ford Taurus, 99 Nitro Bass boat, and a riding lawn mower
Old 03-22-2008, 03:42 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Talking
I just got a 1983 Cabriolet and it came with the windscreen but the "holding part" on the driver side is missing. I try to located on the Porsche CAT or on Pelican and others site without sucess.
If someone got the part number or a photo (make my own bracket), please forward.
Cheers
J.J.
Old 07-23-2009, 08:40 AM
motorcop's Avatar
I have an 84 Cab and am totally in love with it. My son and I took a 300 mile round trip run to the Jersey Shore on Monday, top down both directions, tunes playing, having a great time. I too unlatch the top prior to unzipping the rear window, and then place a towel over it to avoid chafing, seems to work well. As far as the windscreen that JJ911SC is referring to I did not even know that those were available. Will they fit an 84 model? If so where can I get one?
Old 07-23-2009, 01:47 PM
bonkers's Avatar
Originally Posted by imcarthur View Post
Ian's Rules for Owning a 911 Cab
  1. You are the coolest of cool. You are allowed to sneer at all coupe’d drivers. But be kind, because they are ALL envious on a sunny day whether they admit or not. In the picture above, you can clearly see me sneering at Mark in his 930 on the Niagara Parkway - Niagara Falls, Canada.
  2. Top down as often as possible. If you are not top down, the car should be in storage. (or your wife is along for the ride).
  3. Always zip the plastic window out & put a towel on it when folding the top down. This saves the window from wrinkles & cracks & eventual rear obscurity so you might not see that cop car following you.
  4. Practice putting the top up quickly. The only iffy part is zipping the window up - be gentle so you don't rip out the zipper stitching. And THAT is not a fun job to replace - think big sewing needles & blood.
  5. Treat the window with a clear plastic window cleaner every couple of washes.
  6. Never, repeat, never put the top down in freezing temps. I know this breaks Rule 2 but the plastic window is not cheap to replace.
  7. If it starts raining lightly, do not pull over to put the top up. Drive faster.
  8. If your top is manual, always push the metal bar into the fabric as you bring the top down. If it’s not manual, it probably soon will be.
  9. Wash your top every couple of years & spray with a silicone sealant. 303 if you're obsessed or any silicone canvas preservative will actually do the job.
  10. Buy sunscreen & keep it in the door pocket.
  11. Garage the car when not in use.
  12. Never leave the top down for extended periods of time. Always put it up so the fabric doesn’t remain creased & ‘folded’.
  13. When in motion, always have the cab boot cover buttoned down or the top can catch air, chafe & wear prematurely. Another big bill to avoid.
  14. You are the coolest of cool. Keep a pen ready to sign all of the autographs . . .
Sir, I approve wholeheartedly of your rules and your attitude. Of course I should expect no less from one with such a noble name.
Regards,
Ian.
Carrera 3.2 - "Faster, Stronger, Better"
Old 07-23-2009, 04:19 PM
muck-raker
kidrock's Avatar
RULE #1: Drop top.
RULE #2: Carefully place surfboard or large-breasted female in passenger seat.
RULE #3: Drive like a demon.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 07-23-2009, 08:03 PM
Send a message via AIM to Chuck Jones
The only thing I notice in reading through this entire thread.....was that no one ever mentioned lubing the pivot points in the top mechanism. I keep a little tube of that clear silicone lube and put a bit on my finger and work it into the cross sections where the cross braces are bolted or pinned together. I also put a light coating of that silicone lube on the lock-down mechanism and wheel at the front where it cams the top down. I seems that you would want to keep these X joints lubed to prevent them from binding. Just my opinion for what it's worth.
1987 factory Slantnosed 930 Cabriolet/Guard's red
2002 Midnight Blue 996TT X50
1999 Iris Blue 996 (Dash fire burned and totalled 9/07)
Old 07-23-2009, 09:37 PM
Carrera Cab Connoisseur
nyne11's Avatar
Take a look at this old thread Wind Deflector, Wind Stop, Windschott...Finally got one! They come up on Ebay form time to time....good luck.
Dave.
Dave
1986 Carrera Wide Body Cabriolet
1993 Nissan 300ZX Twin Turbo (620rwhp)
2003 BMW 330Ci MSport Individual
1973 Mercedes 350 Custom Convertible
Old 07-23-2009, 10:41 PM
My 87 factory slant came without a windscreen, and it wasnt' listed on the certificate of authenticity or the option codes. Is this something that came with the car, or is it an aftermarket item>>?? I'd be interested if it was something that served a useful function....but I dont see any slots or brackets wehre such an accessory would be mounted.
Old 07-23-2009, 10:46 PM
JJ 911SC's Avatar
Not sure it was an option back then (the Authenticity Certificate is in the mail).
The right inside bracket is screwed on the mechanism. I got the bag for it and if my memory is good it is say Porsche on it. I will check tonight for the part number.
At a Cruise Night Wednesday, I talk to a guy that got one on his Mercedes and he mentioned that it is very effective.
Old 07-24-2009, 04:13 AM
Laneco's Avatar
You guys forgot the most important rule!
HIDE THE KEYS FROM YOUR WIFE!!!
I LOVE driving Steve's cabby! Cabs ROCK! They are just soooo dang sexy... Just wish he hadn't lowered the seat because I can barely see out of it. I think he did that on purpose.
angela
Hello
Old 07-24-2009, 06:23 AM
Please do post a part number. I was totally unaware that a wind screen even existed for the cabs up to 89. Now I'm on the hunt....
Old 07-24-2009, 08:11 AM
JJ 911SC's Avatar
Angela
Hide the keys, I don't have too... Pick one of the following reasons;
A. She does not drive standard;
B. She can not reach the pedals;
C. If she could reach it, she could not depress the "foot long" clutch; or
D. All of the above.
If you pick D, you are correct. Mind you that 2 months ago I was not even dreaming of owing one and out of the blue she send me a link to one for sale (a disaster waiting to happened).
I did some research and came upon this one on a Sunday, saw it on the Monday and made a conditional "technical test result" offer and was accepted and she was mine that Monday night. The Compression Test result came in at 160- 170 Psi across the cylinders.
So, thanks to her, my 45 years old dream finally came through (I saw my first 911 back in 1964).
J.J.
Maybe one day the Black & White beauty will cross path...
Old 07-24-2009, 08:29 AM
JJ 911SC's Avatar
Well it's the usual good news/bad news scenario...
The good news: After going over the frame over and over, I did find the part #... and it is definitely a Porsche item, my windscreen is stamp with, 993 561 179 00 DEZ. I punch it in Pelican 993 catalog and it come up with a "superseded #" message which mentioned that the # has been replace with # 993 561 979 03 DEZ which is available for purchase.
The bad news: Well for a modest $420.65 with a possible surcharge of 20% as it's coming from Deutschland. it could be yours. That is about 2.5% value of what I paid for the whole car.
So at $20 on e-bay, Dave made a very good deal (see old thread refereed on this thread entry #29).
So, I'm half way there, as soon as I can see what the "male" bracket look like, I'll make one.
J.J.
Old 07-24-2009, 03:42 PM
Holy Windscreens Batman.....I'm starting to like....and get used to the feel of a light breeze blowing softly across the back of my neck as I cruise through the countryside taking in all of God's creations....
Old 07-24-2009, 04:17 PM
Used Up User
imcarthur's Avatar
Here's an old thread about windscreens Wind blockers for Cabs - 993 version fit Carerra?
They are available from our host for $457.50 Cabriolet Wind Stop (Deflector)
But the hair blowing free is part of the fun. Just avoid long scarves however or look up how Isadora Duncan died.
Ian
'87 Carrera Cab
Old 07-24-2009, 05:02 PM
nyne11's Avatar
[QUOTE=JJ 911SC;4796876]Well it's the usual good news/bad news scenario...
J.J.
J.J. you appear to have a later model than the one I purchased which mounts entirely differently. Like this one.
The guy I purchased mine from said it came with his 930. Certainly fits mine like a glove and really makes a difference. Good luck.
Dave
Old 07-24-2009, 05:27 PM
t951's Avatar
Are there areas on the cab that are supposed to be lubed? If so, how often and what has been determined to be the best lubricant?
Also, is it easy to change the seals? I am going to have to change ALL of the seals as they are all old and mostly damaged and dry rotted....
tk
08 911 C2S - Sold
13 Audi A4
14 Jeep SRT 500HP
Old 07-27-2009, 02:27 PM
JJ 911SC's Avatar
If anyone need a "pdf" version of the Cabriolet Insert that came with the 1983 Owner Guide, let me know (supply an e-mail address).
J.J.
Old 08-04-2009, 02:46 PM
