Good, that is an indication that the mixture isn't way too rich. Too often someone has set the mixture so rich that the cold start is unnecessary. :eek: The fact that you were able to start it at all says it is richer than it will be when finished. Best, Grady |
I'm getting excited now. I'm within shooting distance of the goal :)
I do have two oil leaks from the lower cam covers, dripping down onto the ssi's so I guess I'd better cure those before I smoke myself out of the garage ! I have an oil leak at the upper cam cover beside #1, and I can't tell if it's from the banjo fitting or from that corner of the cam cover. I'm thinking banjo, mabye it should have had new crush washers ? I simply refitted the banjo with the old washers - what looked like plain flat aluminium washers. Although, thinking about that, the banjo at #4 doesn't leak, and it was fitted the same way. Thats all I have to report for today. It's now Friday evening here, so no more work until tomorrow sometime, if I get the chance. |
Declan,
The salt water in the ‘pond’ conducts electricity. I suspect the ‘excitement’ makes it to the East Coast. The Forum carries it West. :D When you have an oil leak in the cam area and have the valve cover off, always check the rocker arm shafts. Porsche specifies they be torqued at every service. Most ignore this. As I remember Pelican copper (from near London, Ontario) had a rocker shaft slide out just south of the NY border a few years ago (not his fault). Any time you are chasing an oil leak in the cam housing area, this is a ‘must’. Best, Grady |
My suspicions about the banjo leaking were correct, I think.
The washer between the banjo and the fixing point was *just* too small for the banjo bolt. It fiited on the threaded part of the bolt, but would not go any further onto the bolt, so tightening the banjo bolt would never get a good seal between the banjo fitting and the hex mounting point. (Not explained very well, but hope you understand !) Hopefully thats cured now. Edit: The banjo washer gave me some trouble. I ended up dremelling a little off the ID of the old aluminium washer to let it fit the bolt better, and than sorted it. Still have leaks from lower cam covers. I re-torqued all the nuts, and it reduced the leak a bit. need to revisit that. |
I had an aborted attempt today at adjusting part-load mixture.
I had the car idling nice & smoothly, a bit rich on startup until the stat got some heat, then settled into a nice smooth idle around 900/950 rpm. I don't think the car has ever idled for so long before ! I still had a few oil drips from the lower cam covers, but nothing too bad. So, I hooked up the LM1 with the exhaust clamp & went off for a drive. Bit of smoke from oil being burned off the heat exchangers - OK, expected that. Kept an eye on the afr, seemed a bit lean & was getting lean popping. Stopped at the side of the road & richened the part load 2 clicks. Thought there seemed to be a lot of smoke in the engine bay, but OK, probably coming off the heat exchangers. Just let it burn off. Back in the car, turned around & headed for home. Loads of smoke coming from the air vents. I mean loads. I had to stop twice to let the smoke clear before I got home - only about 2 or 3 miles ! So, I'm trying to figure out where all the smoke is coming from. Before I started on this CMA route, I wanted to check if hot air was getting to the stat, so took off the air filter housing and went for a drive to warm it up. Unfortunately, I didn't plug the two pipes that I removed from the rear & underside of the housing. One large pipe from the oil tank, one small breather of some sort. During that drive, quite a bit of oil was spat out onto the top of the engine block. (so much so that when I returned & parked in the garage, I nearly had a heart attack to see so much oil dripping onto the floor, until I realised my stipidity) I simpy mopped up the excess oil but I never removed the tinwork. I'm thinking mabye there is still a lot of oil sitting on top of the block, which is smoking when it gets heated, and that is the same aire which is getting blown through the heat exchangers, into the cabin. Is my logic right ? The air that enters the cabin, through the heat exchangers, is what gets blown down the two pipes at the side of the engine fan, so if there is a lot of oil smoke in the engine bay, it gets blown into the cabin ? What is throwing me off is that this didn't happen when idling, only at faster engine speeds while driving. Any suggestions ? |
What is the oil level (measured with the dipstick)?
There can be some serious issues measuring mixture if the oil is getting into the air cleaner or excessive blow-by. Am I correct, we havent solved the #5 cylinder leak issue? Could this be related? In any event, cleaning up all the spilled oil will help with better diagnosis. Best, Grady Back to the better than most Indy but way too many stupid crashes. G. |
Nuerburgring 24 Stunden was a good result, too. Porsches 1,2,3,5,7,8,9,10. Reminds me of that Monza 956 poster. The 2 other cars were hot BMWs. I wish I could see some of the action and record it. I guess photos will suffice. |
Yep. Looks like I need to do that. Are there any pointers for getting the air-shroud/tinwork off. Do I need to remove the TB's & the mfi pump ? Will have a better look tomorrow. Cheers. Declan edit : Had a look at the PET diagrams & looks like the TB's have to come off to get the air shroud off. I presume the pump will have to come off as well, so I'm off to search for threads on how to do that. |
Well, I had a good poke around this evening in search of my oil leak(s).
As far as I can tell, & see through the fan, there is no pool of oil on the top of the engine block. It all seems quite clean in there, so I'm going to hold off on removing the mfi pump and throttle bodies just yet. On the 4-5-6 side I have a substantial drip from lower cam cover. There is a big drip about every second or so onto the ssi. The smoke from this is passing up into the engine bay past the rubber seal (beside the upper cam cover). I did tighten all the nuts on that cover, a few times, now they are as tight as I dare, but still seem to have the leak from the top edge of the cover, which then finds its way down along the cover surface & eventually drips off the ends of the lower studs/nuts. Looks like the studs themselves are leaking, but its coming from higher up. Don't really know what to do about it. Should I have used some form of sealant when replacing the cover ? It was new gaskets, and the mating surfaces were cleaned. I keep thinking of the rubbery sealant stuff I removed from inside the cover - as if a bead of sealant had been applied the last time the gaskets were done. I know the car had a professional valve adjust shortly before I bought it. I also have wetness from one of the nuts on the upper cam cover, but it seems very slight. more an oil dampness than a proper leak. On the 1-2-3 side, I have a similar leak from the lower cover, again dripping down onto the ssi. What I don't understand, though, is why I am seeing so much smoke coming into the cabin from this side. ( and none from the 4-5-6 side). The ssi's look in perfect condition, but I guess its possible there is a hole in the top that I cannot see, which is sucking in the oil smoke. The amount of smoke is simply amazing. It just wafts up out of the windscreen vent. You would think there was a fire in the dash somewhere. (I checked, there's not !) I also have a small leak on the upper side - It's either from the bottom edge of the upper cam cover, or its still from that banjo where I had the trouble with the washers. It's not a lot, but enough to wet the length of the sheet metal that seals between the upper cam cover and the bodywork. It could still be the banjo, although I checked for leaks there with some tissue paper under the banjo, but only at idle. I think the leak only shows up at higher revs. Again, I don't know what to do about that. Any suggestions are more than welcome. Cheers. Declan |
Amazing what results a search for "oil leak" on this forum will generate !
I strongly suspect my leaks are from the valve cover gaskets. I also see there are a few options from our host. I have bought & used the complete kit : 10-0906-091-M260 There is also a complete kit 10-0906-092-M260 with a silicon bead on the lower gaskets. Then there are the fully silicon gaskets PEL-SIL-VLGK, and also individual Victor Rheinz gaskets. After reading a lot of the threads, I'm still unsure what to do. Is there a preferred method ? I also noticed when removing the lower covers there was some sort of sealant on the studs (as well as on the gasket surface), but I can't see how that would be necessary. So, what is the "done-thing" for the cam cover gaskets. Install them dry ? Use a bead of sealant (loctite 574/silicon/other) ? Use silicon gaskets ? Cheers. Declan |
John Walker has me spray both sides of the gasket with copper gasket spray. It is sticky when dry and he does that on all his paper gaskets. I also fine sanded the covers flat with sandpaper on top of a sheet of glass. Hope this helps.
Yes indeed it helps. Thanks James.
I've read nearly every thread on here and on some other Porsche forums about the gaskets & leaks. I noticed the oil return tubes mentioned as as source of leaks which make their way to the heat exchangers, so I must investigate further this evening. I've also learned that I may have over-tightened the cam cover nuts, which can make my problem worse instead of better. I'll post later when I've had another look |
Right, I got under this evening and had a good look at the oil return tubes, and everything else under there.
Both return tubes, on both sides had a good coating of fresh oil on them. The #2 and #5 cylinders seem to have a lot of burned oil on the fins - quite black & sticky. I cleaned them a bit, and cleaned the oil return tubes, and also cleaned as much of the heat exchangers as I could get to. I did notice the access holes (for the studs) through the exchangers were very oily, and the bottom surface of the exchangers had a fresh oil coating spreading outwards from these holes. Guess I need new oil return tubes. It does have the collapsable tubes, so I thought mabye just replace the seals, but I don't think I'd be able to get a circlip pliers onto the clips to remove the tubes intact, or is that possible ? I can see the clips & reach them with my fingers. The nuts on the exhaust studs looked quite rusty, so I hope I can install new return tubes without having to remove them. I also have a drip from a couple of the lower cam cover nuts. It seems to be leaking out the stud, but I can't be sure. The studs did have some sort of sealant on them which I noticed when removing the covers. (Should I be posting this oil leak stuff in a new thread, to keep it out of my cma/mfi thread ?) |
Sounds like you might want to go ahead and do a proper engine drop. That makes it easier to find all the tough leaks like the MFI pump drive belt and rear main seal. It is also the only way to properly replace the oil return tubes, unless you go with the collapsable temporary fixes.
I thought the collapsable return tubes were a permanent replacement ?
I guess you could run with them for a long time like some people do. Eventually, you should put in solid ones, though. The 2 piece last a while but will leak oil more than the factory spec 1 piece units. They will get you to the next engine drop or when you want to pull the cylinder heads. If the only problem with the engine is the leaky tubes the 2 piece make sense. The factory single tube design has fewer places to go wrong.
You can easily fix everything that might be leaking oil onto the heat exchangers with the motor in the car. The first thing to do is to get those heat exchangers out of your way. Drop the whole exhaust system; it will make some of the oil leak fixes easier. Hit all of the nuts with PB Blaster or something for a few days before you try to loosen them.
You should be able to spin the return tubes so that you gain access to the circlips. Use a well padded pair of channel locks or vise grips if you have to. Just put new o-rings in the ones you have and reuse them; they should remain sealed for a good long time. Use some high temp silicone grease on all of the o-rings. While the return tubes are out, go ahead and reseal the crossover oil return line where it goes into the forward left case. This thing is darn near impossible to work on with the return tube in the way, so take advantage of the fact it isn't. Take the compression fitting apart, then take the fitting out of the case and put some plumber's teflon tape and RTV sealer on the threads and screw it back into the case. The compression fitting doesn't use any sealer, but rather some anti-seize so you can get it apart later if you ever have to. On the right side, remove the long piece of tin, the forward piece of tin (next to the bell housing) and the shroud screws that go into the oil cooler. Take the "J" pipe off that goes to the tank, and remove the oil cooler. Replace the seals inside of there and remount it. The seals like to fall off when they are horizontal in the car, so "glue" them in with some of that sticky silicone grease you used on the return tube o-rings. If you have not replaced the thermostat o-ring, do that too. And the breather cover gasket right next to it. Take the oil temp and pressure senders out and put some plumber's tape on their threads, being careful not to cover the openings in the ends. The pressure line to the MFI pump under the temperature sender likes to leak, too, so put a couple of new compression washers on it. When your valve covers are off, you have an opportunity to seal up the rocker shafts. If they don't already have them, putting in some RSR seals would be a good idea. With any given cylinder at TDC as if you are setting its valves, you can loosen the rocker shafts on it and slide them out into the "dry" areas of the cam towers and put those seals into the grooves. Remember to turn the nut only, not the screw, when loosening or tightening those rocker shafts. When putting the valve covers back on, don't over tighten the nuts. They have a very low torque value (I think something like 8 ft lbs?). That's why they have the nylock nuts - so they don't rattle loose from that low value. Make sure the MFI pump is not leaking as well. The baseplates sometimes leak. The oil supply and return lines sometimes leak. If the baseplate is leaking, you have to remove the pump to fix it. I'm not sure that base gaskets are even available; maybe Pacific Fuel Injection or Henry Schmidt has them. I just reuse mine with a healthy coating of silicone RTV. The pump drive on the forward end of the left cam can leak as well. Yes, it can be replaced with the motor in the car; I've done mine and several buddies'. Take the left rear wheel off. Remove the drive pulley and belt, marking the pulley's orientation (after lining up the "FE" mark on the crank pulley). Remove the forward piece of tin (you have to take the throttle rod off first; it passes through a slot in the tin). From there it is a "simple matter" of prying out the old seal and pressing the new one in. I use a bunch of hooked dental picks to pry the old one out. It doesn't have to be pretty... The new one just presses in with finger pressure. Just make sure it is straight and flush all around. Make sure you line the pulley up the same way it came off; it only uses two of the four holes, and they are not 90 degrees to one another. They are clocked half a tooth off, to allow for that fine of an alignment with the timing marks. Anyway, that should take care of most, if not all, of your leaks. At least the ones dripping on the heat exchangers. Once you are done with all of that, your tuning efforts will be much more pleasant. |
Thats a great explanation Jeff. thank you.
I'm still a bit hesitant to tackle those rusty nuts on the SSI's, but I guess they'll have to come off sometime. Guess I need to go and order some o-rings & gaskets from our host. I managed to find a 2-bar fuel pressure gauge from Simtek Motorsport Electrical, so ordered one, but will be about a week or so before I get it. (For reference, on simtekuk.co.uk it is described as a 52mm Mechanical Fuel Pressure gauge, GAU-054. The photo shows a 7-bar face, but it is actually 2-bar. GAU-053 is the 7-bar version) I also got a reply from Koller + Schwemmer, and they can test the injectors, so I'll send them off while I'm waiting for the other bits & pieces. For reference, I simply emailed info@koller.de explained what I had, and asked if they could test them. They confirmed they can & quoted a ballpark price of €100 for the 6) Cheers. |
In the spirit of Pelican, I just ordered all the gaskets, o-rings, seals, etc from our host, and remembered I had a discount certificate, which almost offsets the postage cost to Ireland :)
I have the injectors all numbered, bubble-wrapped & safely packaged up for posting tomorrow to Koller + Schwemmer. I also ordered 10m of fuel hose (from the UK), with a t-piece for the fuel pressure gauge which has 1/8NPT thread, some anti-seize & some Hylomar silicone stuff. Miraculously, I also have a US gallon can of Marvel Mystery Oil ! Could not find it anywhere in europe, & got no response to several emails to the relevant companies for seafoam & marvel mystery oil. I mentioned the name in passing to a fellow porsche-aholic & he just happened to have some ! |
Koller + Schwemmer have tested the injectors.
They all open too early - 13-14 bar. (188 - 203 psi) Spec is 15-18 bar. I'm going ahead & getting 6 new injectors. |
Declan,
Have them check the new injectors for opening pressure, leak and pattern - should be part of the price. I have seen new ones fail the tests. Best, Grady |
OK Grady.
I've asked them to do that. Thanks for the advice. Declan |
Hmm, I wonder if all the "vintage" injectors will suffer from early opening. I suppose early opening would mean worse atomization of the fuel (an MFI strong point) and fuel too soon in the cycle (although the injectors are probably open pretty much continuously at any decent speed).
Given the price of new Bosch injectors I hope mine don't test this way. Can they be rebuilt? |
Yes, they are not cheap !
Mine are costing me 815 Euro - ( About 1250 US$ ) delivered from Germany to Ireland. I think they are listed at 178 US$ here on Pelican, but I get hit with import taxes on goods from the USA coming into Ireland. Edit : Price is 815, not 851 Euro. |
New injectors all tested good & waiting for shipping pending payment :)
No, I Haven't given up :D
I have got a package from our sponsors with all the necessary seals and gaskets to fix my oil leaks, I hope. :) Haven't had a minute to get near the car recently, but hopefully I'll get some of the seals replaced during this week. Cheers. |
I got the new injectors today, (and the old ones back for spares).
quick update: I've been away on holidays (in a motorhome around NE Spain) for the past 2 weeks, so nothing has happened apart from me moving the package of new injectors into the garage before I left :)
Will report more soon. |
Nothing more done since last post.
Been busy sorting out my daily driver and a mk1 golf gti (rabbit) ! Soon, hopefully. |
Declan,
With the Euro-to-Dollar the way it is, we should have you touring the High Rockies. How about Banff – Glacier – Yellowstone – Grand Teton - Rocky Mountain National Parks! :cool: How about next year – in the 911. There are quite a bit of MFI experience from Edmonton to Denver. Ship the 911 to Boston, tour New England, drive to Toronto, take the CN (with the 911) across the continent to Calgary, tour the Rockies and return to the East via Colorado, Wyoming, South Dakota, Minnesota, Wisconsin, Michigan, Ohio, Pennsylvania, New York and Massachusetts. Everyone speaks English (and Porsche). :D Best, Grady |
At the speed of my work I might be retired by the time I get the car all sorted, so you never know ! I haven't enjoyed working on the two vag cars at all. In the 1983 golf, I had a small water leak from the windscreen dripping down onto the fuse/relay panel. Took ages to sort that out. In the daily, (1998 Audi A4 Avant TDI), I had to replace the front suspension control arms. A day for each side !. What a pain in the proverbial. Rusted bolts, lots of plusgas & a BFH. Both will shortly be for sale, so had to be done. Now, back to a car I enjoy working on. :) |
Finally. Daily driver is sold and mk1 golf gti is back in use as a daily.
Tonight, I even got the 911 up on axle stand again and got to spray the exhaust & heat exchanger bolts with some plusgas, so it feels like I'm finally getting back to it. |
woohoo.
Today was a good day. I've been dreading taking off the SSI's, after reading about the possible/probable problems with the studs. I have no heat source, so though I'd stick with the spray-spray-spray method & see. I've been spraying the nuts with Plusgas for the past week or so. I ran out of plusgas last night so used WD40 instead. Today I went and sprayed them all again, and thought, I'd try one nut to see if there was any chance the PO had used anti-seize when fitting them. Sure enough, absolutley no problem. One barrell nut was a bit stiff, but forward & back about 10 times freed it up & off it came. I stood the ssi up on its end, and about a quarter cup of oil came out :rolleyes: I got brave and decided I may as well take both off. The 4-5-6 side was a bit more awkward. I managed to bend a ring spanner using my bfh, to get at the nuts on #4 and #5. Had awful trouble with teh #6 barrell nut. Not that it was seized, just could not get the hex tool seated properly no matter what way I moved the ssi itself (all other nuts removed at this stage). I ended up using a different hex bit, with a 1/4 drive small socket that fitted up the access hole in the ssi, a long extension and a ratchet. Phew. From looking up at the engine, without the SSI's in the way, I'm pretty sure the oil must have come from teh time I drove it without plugging the breather pipes. There was a lot fo oil on top of the engine at that time, and a lot dripped onto the floor, so I'm sure it made a mess. I now have all the various o-rings & gaskets, so I may as well replace them while I have access. I'm delighted those ssi's came off so easily. I was very apprehensive about getting them off. :) Edit: In my excitement, I forgot the ask the questions : 1. How should I clean out the SSI's ? I guess I could pour in some petrol & swish it all around ? 2. In removing the exhaust box, the bracket to which the bands attach the exhaust simply fell off when I removed the box. It doesn't seem to have been secured anywhere. I presume the two holes are for bolting it on somewhere ? This bracket: http://i24.photobucket.com/albums/c2...0_IMG_6629.jpg Thanks :) |
Declan,
That muffler bracket bolts onto the main engine mount (the part bolted to the engine). Glad to see you making progress. About the heat exchangers – DON’T USE PETROL (gasoline). We don’t want to hear of you in a Burn Unit for the last few agonizing days of your life. Plain Sttodard solvent will clean out the oil. A high pressure, high temperature washer with the appropriate soap will do wonders. Pelican rbuswell and I have some heat exchangers at a radiator shop as an experiment in cleaning. The product they use is a hot lie solution followed by high pressure steam washing. It worked well on my early (slightly rusty) heat exchangers. My 964 heat exchanger came out looking like new. Roger’s ’82 911SC heat exchangers had some reaction to the solution and we quit there. We think there may have been some ‘alumnized’ coating or paint that reacted with the lie. Roger will post some pictures soon. How soon do we get back to the MFI? Best, Grady |
Grady,
Thanks for the advice on the petrol. :) Well, we get back to MFI as soon as I get these oil leaks sorted :) If you recall, I was trying to do the part load adjustment but had to abort due to smoke in the cabin ! So, my plan is fix all the possible sources of oil leaks, put in my new injectors & continue where I left off. Hopefully soon. edit: Is Stoddard Solvent the same thing as "white spirit" over here ? Used for cleaning paint brushes after varnish/wood paints, etc? |
Today I got the collapsable oil return tubes out, and got the tinware removed to get at the oil cooler to do those seals.
The more I see the more I am convinced I don't really have an oil leak, apart from the cam covers. It does really look like the oil that got dumped on top of the engine has found its way down by various routes. I intend to replace the seals & gaskets anyway, for peace of mind. When I dropped the oil, I was amazed at the strong petrol smell. I've hardly done 10 miles in it, but a lot of idling, while setting dwell , timing, etc. |
My oil return tubes are not the OEM type.
They look very similar to the aluminium version available from our host, except one end looks different to this photo. http://www.pelicanparts.com/catalog/...704001-157.jpg The small side has an end which is simply a shoulder for the O-ring, rather than a seat for the O-ring, if that makes sense. I guess I can replace the two end O-rings, and leave the 2 smaller internal rings - They look physicaly smaller than the new OEM version I bought, although I haven't removed one to check for sure. They look in good condition, so would it be wise to simply leave them in place, and add some silicon grease when refitting the tubes ? I don't see any other seals available except the OEM type. edit: Pics of my return tubes: http://i24.photobucket.com/albums/c2...oth_pieces.jpg http://i24.photobucket.com/albums/c2...hort_piece.jpg |
it has been a long time ...
Today my daily driver was in the garage, so I took the opportunity of working on the 911 again :) Replaced lots of o-rings & gaskets, oil cooler seals, & put it all back together. Replaced cam cover gaskets & torque correcly this time. New injectors in, SSI's back on, so hopefully later I'll scare the neighbours if I get her fired up without the exhaust in place :) Cheers, Declan |
Mr. Grady,
Best wishes and good luck. I hope it goes well. Can you siphon the old petrol out of the 911 and into another vehicle? The 911 will like fresh, high octane fuel. Best, Grady |
Woohoo. She lives :D:D:D
I put on the exhaust/silencer & fired up last night :) I thought I might have to bleed the fuel lines to the injectors, but it sorted itself out after a bit of cranking. I have a small oil leak at the breather cover. I did renew the gasket but maybe I didnt clean the mating surfaces properly before refitting :( No sign of any leaks from the return tubes or cam covers :) @Grady - I didn't see your post about fresh fuel until this morning ! I still have to check the fuel flow rate, so I guess thats an opportunity to refresh the fuel. |
| All times are GMT -8. The time now is 08:30 PM. |
