Finally getting around to CMA on my MFI
Hi folks,
After a long time thinking about it, having a few half-hearted attempts, deciding I'd get someone else to do it, deciding no, I'd rather do it myself, etc etc , I'm finally getting around to sorting out (or trying to sort out) my MFI all by myself, so I'll be asking some daft questions on here over the next while. My intention is to get it as good as I can, then get an expert to tweak it the last little bit, so it will be as good as possible. I have a '75 2.7 on MFI. (Yes, MFI) It was converted from CIS to MFI by the PO during a rebuild. I have a big stack of parts receipts, but other than that have no detailed info on what was actually done during the rebuild. My reason for tackling the CMA is very rich idling. Lots of black smoke on idle, very rough & slow idling. Seems to run a bit rough under 3500rpm until it gets warmed up. Once its warm, its goes well, but still doesnt like pulling in low revs, say from 1500 to 2000 rpm, its like a flat spot - If I keep revs above 2k its very good. I've also noticed on a longish drive, fully warmed up, after sitting in slowish moving traffic, say 45/50mph, when you accelerate again there is a good bit of dark black smoke from the exhaust for a few hundred metres/yards, but then it stops again with no noticable smoke until the next slowish traffic, then same thing again under acceleration. So far, all I've checked is the thermostat and airflow at each stack. After reading the thermostat thread on here, I took it all out & cleaned it, put it back together but no noticable difference. I do have warm airflow from heat exchanger to the stat, verified after a drive. I haven't removed the panel from the pump to check if its fully operated when hot. I did use a synchrometer to equalize the airflow across the individual stacks, but in my haste I just reved the engine by ear, I didn't do it at 3k rpm. :eek: I also dived in & tried adjusting the idle mixture on the pump (without doing all the necessary CMA steps :rolleyes: ). I thought it had a little effect but its still very rich. I *think* I remembered the number of clicks and put it back to where it was, but no guarantee I got it right ! Another thing I do have to sort out is the throttle linkage. There is a bit of stiffness in going back to rest position. PO seems to have added a long coilspring stretching towards front of car, secured near the mfi pump, to pull the linkage (crossbar) back into the off position at no throttle, but it still seems a bit stiff. (any pointers on removing & cleaning this bar ?) I've been reading and reading the various MFI threads on here and got some great info. So, I need to start at the beginning. I've invested in a leakdown tester, so once I figure out how to use that I'll check the cylinder leakdown figures. I have new plugs and new Magnecor kv85 leads. To check & set my ignition timing, should I simply get it warmed up and adjust the throttle to keep 900rpm while I adjust the timing, adjusting throttle to keep 900rpm ? (As an aside, my hand throttle works but does not stay in position - I have to hold it or it will fall back down again - I assume it should stay where I put it, and this is simply adjustment of the lever itself ?) When I get to the stage of checking CO at part load, I'm a bit lost. Do I need to secure my gastester somehow and drive it to get it under load, as per the CMA, or is there a different way to do that ? From what I've read I need to get the part load correct before going near the idle mixture, as part load has such a big influence over it. All pointers, suggestions and advice on things to look out for are most welcome. Thanks, Declan |
Wow, it has been a long time lets see if I can remember something about this and get you into more trouble.
The mfi system can not think or sense air flow like cis, efi and even carb's. Thus, everything has to be in its designed position to work. Thus, if you exaust has been changed, air filter dirty, timming off, not getting heat to the thermostat. It will be off so fix all this stuff first. If this thing has been sitting for some time they can gum up and have some issues. I took the covers off mine and used carb leaner in it. There is a lot of oil in there and it should be primmid with oil befor a restart. If it is not indesed correctly when installed or the drive it installed, it will still run but may have a stumble someware in the rpm range and other problems. I had mine 180 deg off. it had a stumble around 4000rpm. Next you need to get the linkages right. As to ballancing the throtle bodys, the main goal is to make sure they are ballanced at idle and off idle when the slack is taken out ot the system when they come off the stops. Thus, you can ballance them at idle, then just advance the idle a bit and use the linkages to ballance it. Go back and make sure it is stil ok at idle. You do not have to go all the way to 3000rpms for balance. Next check the linkage to the mfi pump. You want the pump to be all the way closed or just off the stop at idle. Some times you can play with this linkage to add more fuel. If it is not clear where the pump is fully closed, snap off the linkage and check it's range of motion. Next, the thermostate can be a problem. If you took it apart and put it togeather wrong you are in trouble. You can test it to see if it operarates by heating it in watter or carfully with a torch or heat gun. On my car I went to headers and took this off, made a plate with an adjusting screew and used this for an easy external adjustment. Not recomended. If all this did not work, you can now start adjusting the pump. It is best to test this under load in some manner. If you can add a wide band o2 sensor to your system you can use this. Drive the car on the freeway, get to cruse speed and get your reading. Then adjust the pump untill it is right. There is an adjustment allen screew on the front of the pump. Turn off the car, remove the screew (watch for oil to come out) there is a screw in there that curns with clicks. This thing should be very sensitive to adjustment. As to the black smoke, it should be from running to rich. There is also a lot of oil in the mfi pump. If worn, it migh be possable for oil to pass through to the fuel. The best thing to do is send the pump to Guss at Pacific Furl injection to have it serviced and bench calabrated. There are springs on a cintrifical device that works to determing the position of the space cam (fuel map). If they loose there tension, the pump will advance to fast and make it to rich to soon as the rpms increase. Please check this against other advice, it has been a while and I made up this approach after taking eveything apart and seeing how it works. Good luck. |
Was the complete system installed by the PO? If it was there is an enrichment solenoid and it acts directly on the control punger rack. The energizing circuit for the enrich solenoid is controlled by a thermo-time switch in the breather cover.The enrich solenoid moves the control rack BEYOND FULL POWER SETTING (read rich) for starts. It sounds like you are running very rich.
Declan,
Whoa hoss, we don’t want the cart before the horse. We need to try and figure out what the engine is. What cams? What MFI pump? What throttle bodies? What distributor advance curve? And more. A possible indicator of the cams is to measure the cam timing of both cams. That is easy to do during a valve adjust. More tedious is to measure the profile of an intake lobe. It is more work to remove the chain covers. The MFI pump model is on a plate on the outboard side of the pump. The Bosch number will be in the form “0408 126 xxx” and are in the CMA booklet. The only definitive way to tell the throttle bodies is to remove them and measure the ports. Thil will also let you measure the ports in the heads. All you need are 12 gaskets; six 901.108.391.01 (or .02) and six 901.110.191.00. You can get a good measurement of the distributor advance curve by measuring the advance every 500 rpm from idle to 6000 rpm. Once we know the basic structure of the engine, the cranking compression may give an indication of the compression ratio. While doing this, you can do more of the basic CMA tests; check the MFI pump timing, cylinder leak and much more. “Once its warm, its goes well, but still doesnt like pulling in low revs, say from 1500 to 2000 rpm, its like a flat spot - If I keep revs above 2k its very good.” This may be due to the tuning but it might have 911S cams (basically a 911/83 Carrera RS 2.7). Those are not CIS. :D They don’t start to ‘breathe’ until the 4000 rpm to 7300 rpm range and have little performance below 3000 rpm. With the engine running very rich, I suspect the oil may be diluted with unburned gasoline. This is very dangerous for the machinery. I suggest you change the oil very often until things settle down. Best, Grady |
Whoa hoss, we don't want to over react here let's be practicle please. I thought Mr Declang wanted rational advice, but maybe I misunderstood...so please continue with your $0.75.
Ah, I can see Mr, declang is in good hands and I will lurk about and see what his issue really turns out to be...(I definately will not have 6000 posts in five years with this attitude, ha!)
Declan,
First things first, the rest of the engine must be in good working order before tackling the MFI system. That might be problematic in your case, since as Grady mentioned you don't know what's in the engine - cams, dizzy, ports, etc. I'm far from an expert in these matters - my MFI is also rich at idle, but doesn't smoke as you describe - but I'll chime in anyway. Someone is bound to jump in at some point and straighten us all out (probably Grady). 911ST mentioned all the following, but you need to these correct[ed] before messing with the pump. Adjust the valves and do a leakdown test. Get the engine HOT and use the hand throttle or helper to maintain idle and 6000rpm while you check the timing. The linkage geometry needs to be correct. Requires Porsche protractors and I've never done it myself, so can't be much help. If they're sticking you can pop the caps off the ball joints and apply some grease. If the sticking is in the throttle bodies they probably need to be rebuilt. Balance the stack airflow, as stated early. CMA says to set the part-load mixture before moving to the idle. Yes, an LM-1 with WB02 sensor stuck in the tailpipe is a great tool. You can find CO-to-AFR conversion tables via Google. Enlist a passenger to read the LM-1 output, then you can pullover, make adjustments and continue the road test. Then tune the idle mixture. Injectors? You can have those tested for correct opening. I did and found mine were essentially dribbling fuel constantly. Replace them if bad. No doubt a few dozen critical points I'm missing. Lots of info on the board, maybe find a Pelican or Early S Registry member in your area that's done this before. Good luck! |
7211
Listen to Grady, he is a wealth of information.
OK Folks.
I'm inclined to follow Grady's advice about figuring out what spec engine I actually have. (Absolutley nothing to do with the fact that Grady is my surname !) I'll be home tomorrow afternoon & will get a start on that & report my findings. The PO told me, twice, that SC cams were used. Didn't make sense to me, so I questioned it & was told yes, definitely SC cams. I presume that probably means S cams ? Thanks for the replies so far. Declan Grady |
Declan,
I guess this means we need to pay serious attention to the cams. I don’t think The CIS cams from a 911SC will work with MFI. Obviously it will run, abet poorly and way too rich. It will be interesting to see what actually is there. You are going to need a dial indicator and the little “Z” holder (P207 ) to measure the valve lift at ‘overlap’. This determines cam timing. Depending on what all the components are, you probably will need to make a decision as to how to best bring the collection into a configuration that will run properly. MFI requires the proper SET of pieces to match the particular ‘space cam’ in the MFI pump or vice versa. The choices are pretty much limited to T, E or S. Not bad choices. :D Best, Grady |
Cheers |
Hi folks,
Had a quick look and found the following : MFI Pump is Bosch # 0408 126 019 which is correct for 2.7 according to CMA manual. (Porsche No. 911 110 254 00) It also has numbers 472R and 928 stamped onto the PUMP body near the Bosch ID plate. Only other numbers I can see are on the end of the thermostat housing. 1 425 500 007 1195 226 (I noticed the CMA refers to the 2.7 as the 911SC, mabye this is where the confusion about my "SC cams" comes from ?) On the fuel filter, there is a solenoid on the top, with fuel lines going to each of the 6 intake stacks, but there is no electrical connection to the male spade terminal on the top. (see pic below). I did find a matching cable with female spade connector which looks like its the right length to fit on there. Can't remember disconnecting that at any stage though) Solenoid number is BOSCH 0 330 106 004 I'm thinking this might be the "cold start enrichment" solenoid, so I guess I should just leave it disconnected & insulate the loose wire. I have never had a problem starting. Cheers, Declan Edit: Pics http://i24.photobucket.com/albums/c2.../coldstart.jpg Right stack, showing fuel feeds from solenoid http://i24.photobucket.com/albums/c2...05018Small.jpg Left stacj showing fuel feeds from solenoids http://i24.photobucket.com/albums/c2...05019Small.jpg |
You are right, declan, that is the cold start enrichment solenoid. The disconnected lead goes to the thermal-time switch located on the breather cover. The other connection on that thermal-time switch goes down to the starter solenoid. When you turn the key to start the car and the starter is actually cranking, that wire feeds power to the thermal-time switch, which in turn feeds power to the cold start enrichment solenoid. Until the thermal-time switch heats up, then it opens the connection and quits feeding power to the solenoid. When that solenoid is tripped, it sends fuel directly to the stacks to prime them for starting.
The fact that the car starts easily when cold, without this system connected, further indicates the very rich idle and low speed condition you have already diagnosed. There has to be a lot of fuel coming from somewhere to start a cold engine, and if this circut is disconnected, it can only come from one other source. Sounds like you have a copy of CMA. Also sounds like the motor has the correct 2.7 pump. That's only a part of the system, however. Unfortunately, there is no way to tell what the rest of it is without doing as Grady suggests. You could run all the way through CMA and see where that gets you, if you feel encouraged by finding it has the right pump. Might be worth a shot. |
Thanks for confirming that Jeff.
Since the car does run so well when warm, I am tempted to assume it has all the correct bits & run through the CMA to see how it pans out. I went through my big stack of paperwork and found lots of interesting bills, from piston rings to valves, crankshaft regrind, b/e & main bearings, etc, to lots of smaller bits & pieces from reputable suppliers, so in my mind it looks like the work was done with due care & attention; but no mention of cams, so thats still a mystery. - Would a non-mfi camshaft have the gear on the end for the mfi drive belt, or am I clutching at straws ? Next hurdle is I intended using a "gunson gastester pro" for some of my measurements, but reading the paperwork it's not recommended for CD ignition systems. (It takes a feed from the ignition coil 0V for dwell & rpm measurements.) Does that mean I should invest in something like an LM-1 ? (good euro:dollar rate at the moment ;) and I do like the idea of logging the data :) ) How would I go about checking the cams ? I figure the gauge that Grady referred to above would somehow measure the cam profile, but I've never done anything like that before, so am a bit lost on it ; Is it as simple as rotating the camshaft by so many degrees, and noting the gauge reading, and then correlating all this data to give a profile of the cam lobes for one camshaft rotation ? Cheers, Declan |
Declan, your left cam has to have the extension poking out of the front of the cam tower, or there would be no way to fasten the drive pulley. Any cam profile can be supplied with that extension. Turbos have it as well, but it drives something else.
It would be unusual to find that extension on an SC cam. Some guys hop up their turbos with SC cams, so it is not unheard of, however. But, there are some other compatability issues that make it pretty unlikely you actually have SC cams. SC cams go into four bearing cam towers, where the 2.0-2.7 liters had three bearing towers. So unless it has also been converted to four bearing towers, there is no way to put SC cams in it. The cam bearings are actually larger in diameter in the four bearing towers as well, leading to yet another compatability issue. The seal on the front of the left cam, where it pokes out through the tower so the pully can be fastened, is only made in the proper size for three bearing towers. It is too small in its O.D. to press firmly into a four bearing tower, and will leak like hell. A custom seal holder needs to be made, that will hold a turbo pump seal in the hole on a four bearing tower. Henry Schmidt at Super Tec makes them, by the way. So, working our way through this (somewhat) logically, it is clear there would be a number of problems in fitting SC cams. It is clear the original 2.7 CIS cams could not be used; the left one lacks the MFI drive. Some one had to buy some cams for this thing. The logical choice would be "S" cams. Three bearing, with the pump drive extension. And, best of all, original spec for the 2.7 RS. Which is where the "019" pump came from. With the "due dilligence" displayed in finishing up the rest of the motor, would it be a stretch to assume the correct cams were ordered? They had to be replaced anyway. They had to fit three bearing towers and have an MFI drive. That leaves the "T", "E", and "S" as readily available, off the shelf choices. Some one would have to had put a great deal of extra effort into fitting anything else. I know; I just finished a 3.0 on MFI, with four bearing towers. I've been through these headaches. So, at this point, I would make everything right per CMA and see where you are. Yes, an LM1 is a great tuning tool. Get one if you can. I could not have gotten mine running properly without one. |
Declan,
The dial indicator and “Z” bracket are the normal tools for checking and setting the cam timing on a 911. Porsche specifies the valve lift at Top Dead Center Overlap (TDC overlap same as Z1 overlap). This is where both valves are open as opposed to TDC Compression where both valves are closed. The specification for the MFI 911S (and Carrera RS 2.7) cam is 5.00 – 5.40 mm with the desired value 5.20 mm. You can easily check both cams with just the intake valve covers off. This should be a good clue. Yes, it is as simple as rotating the engine to Z1 and taking a reading. To measure the profile the measurement is just repeated at sequential angles of rotation. Your feeling ‘no power’ at low rpm may just be the ‘S’ cams exacerbated by the super rich condition. Once the mixture is correct it will ‘scream’ at high rpm but will never perform like CIS or DME at 2000 rpm. That is what a 2.7RS is all about! Jeff is correct. If the engine will start cold without the cold start solenoid valve functioning, the system is way too rich. After we do ALL the other stuff, we will get there. Remember the oil change. BTW, there is a cold start enrichment solenoid on earlier MFI pumps (’69). It is a second solenoid just below the shut-off solenoid. It operates directly on the rack in the pump and forces it full rich – richer than the engine ever runs under other conditions. It is useful to use in place of the cold start solenoid valve on top of the fuel filter console because it eliminates the second fuel circuit (fire safety). You can retrofit the two-solenoid governor cover to the later pumps. Please post the part number for the pistons & cylinders. That will be invaluable info. You are correct in that only MFI cams have the extension to drive the pump. However, other cams have two threaded holes in the end and you can mount a separate (custom) extension to drive the pump. I’ll let others who have first-hand knowledge advise on the current crop of exhaust analyzers. I too like data acquisition. Best, Grady |
Jeff, thats great info. thanks :)
As it turns out the PO was not the person who did the rebuild. It was the Previous-Previous-Owner. I did come across some printouts of email communication in the file between PO & PPO and it stated "Sc cams" so I'm guessing at S cams, with a simple typo. The PO, being non techy, passed that info on to me as SC Cams, and confirmed that when I queried it. Some of the restoration photos show an immaculate rebuilt engine, which leads me to believe it more than likely was done correctly. I think I'll have to order an LM1 and do the full CMA then see how it works out. Now to discuss with my accountant (swmbo !) edit: cross posted with Grady's post. Grady, thanks for that explanation. Makes sense now. Considering the temperatures here do not get very low, would I need any cold start enrichment ? Lowest temps would be around 5C or 6C ( roughly 42F ) - would that require the cold start enrichment ? I cant find any invoices for P's & C's, so don't have part numbers. Are cylinder P/N's readable with engine in car ? Cheers. ps. oil change done about 30 miles ago. Most money I ever spent on oil ! |
sorry. double-post
Ack, I posted a big long reply here and I'm sure it appeared but its gone now :(
Basically, what I was saying was that I can't locate a Z-block here to measure the cams, so I'm going to order from our host :) Also going with an LM-1 & rpm to help with my adjustments. I decided to have a look at plug leads and in the process I noticed some other screened cables and "something" all taped up. http://i24.photobucket.com/albums/c2...ned_cables.jpg I found the screened cables were from coil & points back to CD unit. The "big taped up thing" had me puzzled. Some mysterious porsche technology I knew nothing about ? I got the cable assembly out http://i24.photobucket.com/albums/c2...05028Small.jpg untaped it http://i24.photobucket.com/albums/c2...05030Small.jpg untaped some more http://i24.photobucket.com/albums/c2...05031Small.jpg and ended up with this http://i24.photobucket.com/albums/c2...05034Small.jpg Crazy ! Is there any need for screening of these cables ? I noticed an unscreened cable from the CD unit spade connector over to the fan housing, earthed with the same earths from the other screened flexes. Does that make any sense ? Any reason for that ? Staying on electrics, there is a push-button switch on that electrical panel, with a figure-of-eight cable (like thick speaker cable) that disappears off into the body work on the right hand side. What is the switch for ? http://i24.photobucket.com/albums/c2...ttonswitch.jpg Lastly, there is a largish pipe which comes from two fittings on the throttle bodies for cylinders 1 & 2. I didn't trace the other end of the pipe. What is it ? Vacuum ? Why such large pipes ? http://i24.photobucket.com/albums/c2.../mfi/pipes.jpg Thanks. Declan |
Declan,
OK, I can answer some of your questions. The plumbing at the #1 & #2 intakes is originally for a Sportomatic transmission. Do you have a Sportomatic? Occasionally these vacuum ports are used for the ‘power brakes’ but those start in ’77 and aren’t normally on a ’75. Is the vacuum system hooked to anything? If not, we need to plug the ports in the throttle bodies. If those vacuum check valve ports are open to the atmosphere, I think we found the source of the ‘popping’. They are drawing air at idle, causing #1 & #2 cylinders to be exceeding lean – thus lean pop. If this is the case, I suspect you will find only #1 & #2 cylinders popping through the intake. This also skews the overall mixture readings. Two cylinders are very lean and the other four are too rich. First plug the air flow to these two check valves. I’ll bet the ‘pop’ stops and the mixture settles down – still too rich. This may be the ‘big deal’. I’m somewhat surprised at the length of the harness to the CDI. I wouldn’t be surprised to find this was a harness for some other car. The shielded wires are necessary for Radio Frequency Interference (RFI) suppression. The 3-pin Bosch CDI has very fast risetime. Porsche (and Bosch) did this to overcome plug fowling. Fast risetime translates (with Fourier expansion) into very high (radio) frequencies. The braided shielding is to prevent interference with nearby radios, including the one in the 911. This RFI can even self-induce the CDI to fire multiple times. Please post images of the other braided cable from the CDI box ground to the fan housing. This may be an attempt to reduce RFI. It is useful to check some other grounds (‘earth’ connections). Is the braided ground strap between the transmission and chassis in place? Is there a braded ground strap between the CDI and the ground connection on the left inner fender (behind the CDI)? Regarding the wiring, the ignition pulse from the CDI box to the ignition transformer (‘coil’) is about 400 V! There used to be a warning decal on the ‘coil’. Touch the lead and it will knock you across the room or worse. The push button switch on the electrical relay panel is not OE Porsche. I suspect it operates the starter or something in the cold start circuit. Follow the wires. When your MFI is adjusted correctly, you will need the cold start enrichment to easily start at anything below about 70F. Without it you should not be able to start it at 42F. This is an indication as to how rich it presently is operating. Change the oil. Smell the petrol in the oil! :eek: SmileWavy Best, Grady |
Thanks Grady,
I do have servo assisted brakes. The rubber pipe from these disappears off into the body from the engine bay, haven't looked for the other end yet, but I guess its vacuum for the brake servo. Edit: Confirmed. Pipe does go all the way to the front to the brake servo :) Quote:
I guess I just shorten those two cables to required length. The other ground cable from CDI unit to fan housing is a simple violet/black flex, I'd guess about AWG18. No screening, and not routed with the other screend cables. (see pic) http://i24.photobucket.com/albums/c2...th_from_CD.jpg I have not yet checked for braided starp from transmission to chassis Will check this evening. Any pointers on where exactly this should be ? There is a braided ground strap between the CDI and the ground connection on the left inner fender (behind the CDI) Quote:
One of the 2 wires to that switch wire is off. Perhaps it broke off while I was manhandling the unit to remove it, but I'm not sure. Will trace & report back. Thanks again for the input. It is very much appreciated. edit: Just a thought, I do have a "gunson gastester professional". Can I use that for dwell & tach readings ? The instruction manual says not to be used with CD systems ? Cheers, Declan |
further digging today ....
I checked the length of the link to the mfi pump. exactly 114mm centre to centre, so thats good. I have a problem where the throttle linkage does not fully return to the off position. It returns almost fully, but not enough to operate the microswitch. I disconnected the two links to the throttle bodies and checked them for binding, but all seems free. :) I removed the throttle cable link also, and it seems very free to move by hand. The deflection roller seems free enough to move, no binding, but the end of the helical (?) spring seems to pop out of its holder very easily, so there is no return effect at all. Even with the spring reseated properly, it's enough to move the deflection roller back to rest, but not enough to operate the microswitch. - Should it be enough pressure to operate the switch ? I did try getting one more turn on the spring, but the end just pops out of the hole again when you move the deflection roller. http://i24.photobucket.com/albums/c2...05040Small.jpg I noticed there is space for a second spring on the right hand side of the deflection roller, but none is there, which seems correct http://i24.photobucket.com/albums/c2...05042Small.jpg Slainte, Declan |
I think you need a new spring to really fix this problem.
My spring was strong enough but the microswitch was not being triggered by the retuned trottle arm. I tested the switch with a volt/ohm-meter and it functioned electrically. I could hear it working mechanically so all I had to do was to adjust the screw which contacts the microswitch button. It is located on the end of the throttle arm. In a similar way to adjusting the valves, screw in the adjesting screw on the throttle arm. This will make contact with the button earlier and put the arm in a position where it recieves more force from the spring, solving the problem. If the microswitch does not read infinate resistance when open and near zero when closed, the switch is bad. You can pick up a suitable replacement from Radioshack or Newark Electronics or similar electronic parts suppliers. Don't go to the dealer:) It wll cost 8 times as much. Just take the switch into the local Radioshack and tell them you need one of these. Edit: I don't have a spring on the passenger side of the throttle crossover linkage, either. Hope this helpsSmileWavy |
Yes, Flieger, thats want I needed to know. Thanks.
And another thing .....
(should I just continue posting in this thread, instead of starting new threads ?) I decided to have a look at the throttle bodies, so started trying to remove the right side. Got the stacks off but ran into a problem trying to take the pipes off the injectors. I cant budge them. I presume they are a "normal" thread ? (clockwise tighten, anticlockwise loosen ?) I did get a good look at the butterflies and the underside of all 3 are very dirty. (Pics below) I guess I need to persevere & get them off for cleaning ? They do move freely, no binding, no sticking closed, so at least thats something. I did notice, however, the spring on #5 is not as strong as the other two springs. It does close the butterfly, but not with the same force as #4 or #6 http://i24.photobucket.com/albums/c2...ttle_body1.jpg http://i24.photobucket.com/albums/c2...dies_4_5_6.jpg Stamped on the throttle body, closest to me, (#4?) is the code : 02 73 257 On a separate note, while following the vacuum pipe to the brake servo up front, I noticed a bunch of wiring with two multipole connectors laying loose in behind the servo. I'm guessing its from an older alarm/immobilizer install, but the connectors seem quite an old style. anyone recognise them ? http://i24.photobucket.com/albums/c2...connectors.jpg Slainte, Declan |
OK, Today I persevered, and managed to get the pipes off the injectors, and the throttle bodies off one side (4,5,6).
They are (it is ?) very dirty, and will take a lot of cleaning. I Measured all 3 at around 37mm. mabye a point or 2 more edit : more like 36mm, see later posts ... (battery gone in my digital vernier !) |
Did we ever get the serial number for this engine? 37mm+ MFI throttle bodies sound interesting....
JA |
the original engine was 911/41
This is stamped on the casing, near the oil pressure sender, and matches the engine serial number. It was rebuilt, adding the MFI supposedly to "RS Spec", but I'm unsure what work was done. edit: I measure the TB's again. 37.x at the top, but only 35.x at the bottom. The ports on that they mate to are 37.x edit: nope. more like 36mm ! edit2 : I found this thread http://forums.pelicanparts.com/porsche-911-technical-forum/117171-mfi-induction-chart.html which gives the ID of the various parts of the intake system. But, I cannot match my measurements to any of them. I seem to have :Top opening of throttle body = 37.x (mabye 38mm at a push) Bottom opening of throttle body = 35.x mm Cylinder intake port. = 36 mm Closest match I can find would be the S setup, with 38, 36, 36. There is quite a build of carbon in the TB's, enough that can be scraped off, but I doubt it would add up to 3mm on diameter. Mabye 1mm worst case, making it close to 36mm. edit3: I measured and measured and measured. I'm pretty sure the setup I have is 38,36,36 from top of TB, Bottom of TB & intake port. I must have been measuring the intake port gasket, and not the port itself when I got 37.x ! |
nothing much to report yet. still cleaning the throttle bodies !
The main throttle return spring is the one on the pump itself. It is quite a stiff spring and, if it is not returning the whole works to the idle position, none of the other springs will, either. The one spring on the rack and the six on each butterfly are very weak, and are only really meant to take the slop out of the system that is inevitable with all those ball cups, pivots, and such. They are not meant to, and will not overcome any binding in the rack or throttles.
All throttle bodies are tapered top to bottom. You have the standard S/RS sizes. It's looking more and more like your motor was properly converted to an RS spec 2.7. That's good news. Looking at the state of those butterflies, it's a minor miracle it ran at all. If they are that carboned up, the air bleed ports are probably all but shut. Soak those things in some Berryman's for a week or two to break up all the carbon. Don't stop cleaning until they are well and truly clean. Keep at it until the bypass passages are open and the butterflies move freely. That will solve a lot of your problems. Make sure all of the stops are adjusted properly as well. The closing spring pressure should not be taken up by the butterfly resting on the side of the bore. They do have to fully close, but that is different than bearing on the bodies under spring pressure. If they do, they will soon wear grooves into the soft metal of the throttle bodies. Then they're toast. Anyway, unhook all of the short linkages so each butterfly will move on its own. Back off the stop screws until the butterflies rest, when closed, on the bores. Then turn the screws in just enough to take the spring pressure; you don't want the butterflies to move. You should be able to hold them up to a stong light and not see any light around the butterflies when you are done. Set the two short rods (from the center #2 and #5 to the fore and aft #1, #4, #3, and #6) so there is no preload with all of the butterflies shut. When you put them back on the motor, you want no preload in the rods to the rack. With the rack to pump rod at the specified length, you should be able to hook up the two rods to the throttles without having anything move. Keep adjusting them until you get them right. They don't have to be the same length; CMA specifies a pretty broad tolerance on them to achieve correlation. By doing all of this in the manner I just described, you have achieved correlation per a later service bulletin that Porsche issued as a supplement to CMA. This is how it can be done without the protractors. So, in essence, when it's all back together you are looking for a few key things. The pump is on its idle stop. The throttles are on theirs. The pump to rack rod is the specified length. There is no preload anywhere; all rods can be connected and disconnected without anything moving. Then, and only then, will you be ready to start adjusting bypass screws for synchronization. Then, and only then, will you be ready to start turning screws in the pump to set part load and idle mix. You're actually pretty close now; eliminating the crud will make everything else fall into place quite easily. |
Declan,
I would soak the throttle bodies in B-12 chemtool, or whatever the Irish equivalent of nasty, smelly carburetor cleaner is. Carbon in the air correction tubes or on the throttle plates will prevent you from achieving perfect correlation. Here's my take on the subject, you may have already read this. http://forums.pelicanparts.com/porsche-911-technical-forum/277484-mfi-diaries-correlation-last.html?highlight=correlation A little motivation when you are cleaning your throttle bodies. . . :) http://forums.pelicanparts.com/uploa...1206787360.jpg http://forums.pelicanparts.com/uploa...1206787396.jpg http://forums.pelicanparts.com/uploa...1206787576.jpg http://forums.pelicanparts.com/uploa...1206787621.jpg p.s. Higgins what county you from with a signature line like that? :) |
Geez John, "motivation" or a crushing feeling of inadequacy?;) Those are almost pornographic to a guy like me...
The Higgins family hails from County Sligo, so not too far at all from our friend declang. |
I'm sobbing in my Guinness looking at those "what it should look like" shots. Wow.
Yep. Sligo is only 70 miles from me. |
I can't locate any berryman stuff over here, or anything similar for steeping them in.
Had a go today with some brake cleaner fluid & it seems to do the trick with a bit of toothbrush scrubbing. Guess I'll be a while at this stage ! |
Well, after a lot of scrubbing & spraying, I've got them clean.
http://i24.photobucket.com/albums/c2...5072Medium.jpg Took a lot of scrubbing with a toothbrush & some brake/clutch cleaner. http://i24.photobucket.com/albums/c2...5069Medium.jpg |
Wow, what a difference. Good job. With the same kind of care and diligence applied to setting them up, you will be well on your way to MFI happiness.
Thanks for the words of encouragement Jeff :)
| All times are GMT -8. The time now is 03:50 AM. |
