Designer King
Paulporsche's Avatar
Need Help Locating Window Seal
I need to replace the fuzzy lined seals in which the front windows ride. I am having trouble locating what they are. Are they part number 91154290500, Window Guide, or is there a rubber part that slips into it? I am not referring to the squeegee.
Do I want "Window Slot Seal" 901-531-935(6)-20-M20?
This is for a 77 coupe.
If I knew how to post a pic from the parts diagram I would have.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 03-22-2008, 12:26 PM
Try the catalog search again and type "door window felt" into the search box. I think that is what you are looking for--the part #s end in ----M260.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 03-22-2008, 07:13 PM
The PET Shows three parts but they all end up being the same number:
i) 911-542-905-00 for the top channel
ii) 911-542-905-00 (same as #i) for the front channel
iii) 911-542-905-00 (same as #i & #ii) for the rear channel
when this it plugged into the Pelican, it shows on the link below as #27
http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search.cgi?command=show_part_page&please_wait=N&make=POR&model=911E&section=BDYsl2&page=1&bookmark=3&part_number=911-542-905-00-M260
Old 03-22-2008, 07:38 PM
Designer King
Number 27- Coupe Window Channel it is. 911-502-905-00-M260.
Thanks to the 2 blue guys!
Paul
Old 03-22-2008, 08:17 PM
