Designer King
Need Help Locating Window Seal
I need to replace the fuzzy lined seals in which the front windows ride. I am having trouble locating what they are. Are they part number 91154290500, Window Guide, or is there a rubber part that slips into it? I am not referring to the squeegee.
Do I want "Window Slot Seal" 901-531-935(6)-20-M20? This is for a 77 coupe. If I knew how to post a pic from the parts diagram I would have. Thanks
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone Last edited by Paulporsche; 03-22-2008 at 12:46 PM.. |
Try the catalog search again and type "door window felt" into the search box. I think that is what you are looking for--the part #s end in ----M260.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
The PET Shows three parts but they all end up being the same number:
i) 911-542-905-00 for the top channel ii) 911-542-905-00 (same as #i) for the front channel iii) 911-542-905-00 (same as #i & #ii) for the rear channel when this it plugged into the Pelican, it shows on the link below as #27 http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search.cgi?command=show_part_page&please_wait=N&make=POR&model=911E§ion=BDYsl2&page=1&bookmark=3&part_number=911-542-905-00-M260 Last edited by bluesky; 03-22-2008 at 07:48 PM.. |
Designer King
Number 27- Coupe Window Channel it is. 911-502-905-00-M260.
Thanks to the 2 blue guys!
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
