-   -   Is there no interest in hard to get replacement decals? (http://forums.pelicanparts.com/porsche-911-technical-forum/399786-there-no-interest-hard-get-replacement-decals.html)
dentist90 05-24-2008 10:43 AM
Yes! I just noticed the part # and punched it in, TA-DA! It's in my project list as we speak.
nyne11 05-26-2008 08:00 AM
Originally Posted by dfk911sc (Post 3961751)
Dave,
This is the alternator housing metal decal 89mmX45mm
http://forums.pelicanparts.com/uploa...1211645918.jpg
http://forums.pelicanparts.com/uploa...1211645940.jpg
These are from the DS door pillar the large is 22mmX64mm the small 27mmX30mm
http://forums.pelicanparts.com/uploa...1211646023.jpg
Thanks Dan for the photos and info. Any chance of a better one of the alternator decal just so I can read everything on it including part No.
Dave.
nyne11 05-26-2008 08:22 AM
Just a quick follow up. Thank you all for your continued support on this project. It is coming along but does take time to reproduce these decals from photos alone. I have produced one of the alternator decals on the gold foil media I ordered and it will be tested at the end of the month for appearance and durability. First impressions are very promising.
http://i189.photobucket.com/albums/z...38-016-035.jpg
http://i189.photobucket.com/albums/z...38-016-038.jpg
Keep them coming guys.
Dave.
deshetlr 05-26-2008 09:13 AM
Dave,
Nice work!
pope 05-26-2008 01:14 PM
Great job. Here's the one on a 1970 911E
http://forums.pelicanparts.com/uploa...1211832867.jpg
tedward515 05-26-2008 01:45 PM
Those are looking good. I don't know if you have done this one already or if its in good enough shape to devolope a copy from. It's diameter is 4 and 1/8 inches or 105 mm (if my conversion is any good). I put a piece of white paper behind it to help it show up better. Hopfully you can use it.
http://forums.pelicanparts.com/uploa...1211834312.jpg
Flieger 05-26-2008 02:17 PM
You can get the '69,'70,'71 Weltmeister decal from the Early 911S Registry.
They have the 1969, 1970 Marken Weltmeister ones as well, just what you have pictured.
1969 is also available as is CanAm 1972
http://www.early911sregistry.org/WeltmeisterDecal.html
This goes to a good cause, too, supporting the early 911S community. The forum is not easy to maintain and the knowledge contained in it from the experts in the club is very important to keep the longhoods going.
the 05-26-2008 02:18 PM
The thing about replacement or replica decals, is they are great if they are EXACT replicas.
If they are not, or are not very, very close, I'd rather have the old worn out real ones.
nyne11 05-26-2008 05:38 PM
http://forums.pelicanparts.com/uploa...1211848634.jpg
pope 05-27-2008 01:28 AM
Excellent. Great job.
I think the fonts should be a bit narrower though. I'm sure you can get it just right so if you put them side by side you cannot tell the difference between old and new.
nyne11 05-27-2008 02:00 AM
Thanks for the input. Bit hard to tell unless I have a "Flat" example.
Can you possibly take higher res pics, even if they are in segments ( say three, left to right) that will give me a better idea of exactly what is needed.
Dave.
pope 05-27-2008 03:54 AM
Dave, check your PM's
dentist90 05-29-2008 09:54 AM
Originally Posted by dentist90 (Post 3961862)
I've been looking for this one, from a 84 coupe:
http://forums.pelicanparts.com/uploa...1211649684.jpg
Pieces are missing (especially the French parts). Can anyone help with the missing parts?
This sticker is listed on PP but is unfortunately No Longer Available. I suspect many such stickers are NLA even tho they have a part #.
JT912 05-30-2008 08:52 AM
This is from a '68 w/ emissions. Should have a red boarder. I am kicking myself for passing one up on Ebay a while back.
http://forums.pelicanparts.com/uploa...1212162732.jpg
acapella8 07-25-2008 06:39 AM
Dave,
Any chance the Bosch coil sticker could be reproduced.
http://forums.pelicanparts.com/porsche-911-technical-forum/421665-oem-sticker-bosch-coil.html
Thanks.
Tom
Carrerax 07-25-2008 07:08 AM
Dave, Im in for a full set for a 1970 911t. I need all the ones that go on the rear panel. Mine are all missing. Thanks! Mark
nyne11 07-25-2008 08:45 AM
After some pretty negative feedback to a response I posted on a recent thread I decided I would not continue with this exercise. However it appears that there is some interest out there for a number of now hard to get decals. If I do continue I will need some help in identifying the photos supplied to the correct model and providing photos with legible text and graphics as well as sizes so I can reproduce as close as possible. I have done quite a few already and will post the samples here so that members can help identify what model they are off and also identify what ones are missing.
Please understand that I make every attempt to reproduce these decals as close to OEM as possible. You must also understand that I am not a qualified graphic designer or graphic artist but am doing my best to provide Pelicans with alternatives. I am not in it for profit or gain of any sort. It is time consuming and I appreciate any constructive suggestions as there will be mistakes and I will do my best to correct them. In the end though it will be take it or leave it.
Having said all that. Here is what has been done so far. The gold background is for visual purpose only and the final decal will be printed on gold foil with a UV and chemical protective covering. The ones I have printed so far look good to me.
http://i189.photobucket.com/albums/z...Clearance2.jpg
http://i189.photobucket.com/albums/z...isc/paint2.jpg
http://i189.photobucket.com/albums/z...ring-Order.jpg
http://i189.photobucket.com/albums/z...estickers4.jpg
http://i189.photobucket.com/albums/z...nestickers.jpg
http://i189.photobucket.com/albums/z...estickers3.jpg
http://i189.photobucket.com/albums/z...estickers2.jpg
I don't mind if someone else wants to take this on or if they want the templates to print them themselves. However I do mind if they are going to be used for profit or without permission.
SmileWavyDave.
Carrerax 07-25-2008 10:03 AM
Thanks. I just dont know what ones I need. Where can I find what was originally on my 70t?
GH85Carrera 07-25-2008 11:22 AM
One sticker I want is the blue sticker inside the trunk right above the brake fluid reservoir. I don't have one on my trunk so I can't photograph it for you. Maybe one of the other guys can post a photo of it.
deshetlr 07-25-2008 11:41 AM
Dave,
I was hoping you would take up the project again. This community is in need of these labels and as the cars age the need will only increase.
My interest is in the Shell sticker. It goes on the hot air socket on a 1986 3.2L Carrera. it is 2"x5". My understanding this sticker changes frequently by model year so I cannot say what other years it is correct for.
