RSM-M491's Avatar
Question 911 Tach not Straight
One more question, my Tach is not positioned properly, the "1" is at 6 o'clock, I assume that is wrong, so is there a way to "rotate" the tach to the proper position?
Thanks!
Rod
1989 911 Targa M491
1980 Triumph TR8 (sold)
2006 BMW M3 (Interlagos Blue)
Old 09-24-2010, 09:09 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Thanks!
Rod
You can pull the tach out, and re-orient to the correct position.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 09-24-2010, 09:19 PM
Nine17's Avatar
Many of us have rotated our tachometers so that the 6800 rpm power peak is at 12 o'clock. It's an old racing trick that helps us pretend that we're Al Holbert in an RSR...
'88 Carrera Coupe G.P. White
Old 09-24-2010, 10:43 PM
Walt Fricke's Avatar
Youwsir, Nine17.
I also rotate the speedo so I can see the part I need to know about through the spokes of the narrower wheel.
Old 09-25-2010, 12:46 AM
5String
I'm also one of those who has rotated the tach so that the shift point I use is at 12 o'clock. No pretensions about being Al Holbert, though - he was lots faster than I'll ever be.
5String
Tell not a soul that you have seen me; breathe not a word of what I say....
The Northwest Files
Old 09-25-2010, 08:50 AM
Tach Twist
If you've never done it before it may not be obvious. The tach is just "press fitted" in a rubber gasket without any retaining screws/bolts/etc. You should be able to just pull it out while trying to "wiggle" it. If you need to pry it a little with a screwdriver/etc. be gentle and watch your dash and especially the relatively soft metal rim around the tach. Then just push it back in, lined up as you want.
87' Carrera
95' 993
Old 09-25-2010, 09:19 AM
I always found that it was easiest to pop out the left hand gauge and the pop the others out from behind using the whole left by the first. I never liked the idea of using a butter knife or any thing like that. I always had my tach and speedo tilted.
The standard is to not have any of the gauges tilted.
Old 09-25-2010, 09:25 AM
@ 3 digits
rayporsche's Avatar
oh....oh....oh...ooooohh.....but that 'is' the proper position, if you'll drive your Porsche 'properly' that is...... LOL
'Enjoy the little things in life, for one day you will look back and realize they were the big things'
Old 10-01-2010, 03:05 PM
Senior Advisor
James Brown's Avatar
But now the left turn light is up and right is down, I'm so confused!!!
08 Cayenne Turbo
Old 10-01-2010, 06:31 PM
