limble's Avatar
Replacing engine compartment insulation
1979 SC. Engine is out for other service items.
I ordered the factory engine compartment insulation. Any tips on what type of contact cement to use? Other lessons learned?
Mike
Thanks,
Mike
When I was a kid, I didn't want a stupid pony, I wanted a PORSCHE.
1970 911T Coupe, 1979 911SC Targa Euro, 1971 Honda CT70 HK Trail 70 (the ultimate in two wheeled transportation)
Old 03-29-2008, 10:16 PM
AutoBahned
RWebb's Avatar
search button
Old 03-29-2008, 10:54 PM
wastintime's Avatar
Send a message via AIM to wastintime
I'm not sure why everyone gets so pissy when someone posts a question that's been asked before... but yes, if you search there are numerous answers to this question. 3M makes a great cement for doing engine compartment liners.
-Andy
'67 912, '92 C2, and '93 RSA - all gone
Old 03-30-2008, 07:29 AM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
3M spray works well. Actually I just replaced mine and didn't need any adhesive at all to get it to stay up/in place properly.
Black Cars Matter
Old 03-30-2008, 08:03 AM
deshetlr's Avatar
Pretty simple process. Clean the surface, getting all the loose junk off. Then dry fit the pad, skin side toward the engine. Once you are comfortable with the fit pull it out and get ready to glue. Use 3M trim adhesive around the perimeter and form a big X. It is also good to put a bead where the pad makes a big bend. Then use some 3M spray adhesive on the whole piece (this is all on the reverse side from the skin. Position it carefully and apply pressure to assure adhesion. You are done! And yes it does reduce sound in the cabin.
Scott
'86 911 Carrera Coupe, PCA, PBC
Old 03-30-2008, 08:30 AM
ToddM's Avatar
Send a message via AIM to ToddM Send a message via Yahoo to ToddM
Appbiz has some great engine sound pads, you should check them out
-Todd
'82 911 SC Coupe w/'92 3.6L, bulletproofed 915/62 w/GT LSD & Wevo goodness, Rennsport RSR/Bilstein Sport, SRP ARB, ER Polybronze, BK strut brace, 15x7/8" Fuchs.
Sold: 92 964 Turbo, 81 SC, 96 993 Coupe, 82 SC, 89 Carrera Cabriolete
Old 03-30-2008, 08:35 AM
Mitch Leland's Avatar
Howdy,
I had my upholster sew up a insulation pad for me, we used a closed cell 1/4" foam under a shiny silver vinyl, then I used an industrial strength Vel-Cro have attaching. So far it's worked quite well...
I was more interested in cleaning up the firewall, than sound proofing. Also the factory insulation will decompose sooner than later so while it's not "factory" I think it will hold up longer.
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 03-30-2008, 09:29 AM
ToddM's Avatar
Mitch
That is slick!
-Todd
Old 03-30-2008, 09:49 AM
