Throw it on the ground!
Simple Instrument Bulb Question - How many?
Good God there is too much info out there on instrument lighting!
Simple question: My clock bulb is out. Will replace with OEM 2W bulb from our host and thought I'd go ahead and replace them all. How many do I need to do all the gauges in a 1987?
Thanks!
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 03-30-2008, 07:49 AM
My quick check of the diagrams shows this:
Tach-2
Speedo-2
Clock-1
Fuel gauge-1
oil gauge-1
This is for the 73 gauge set for illumination (back lighting), but I think the 87 uses the same set up. Hopefully, others with first hand experience of later gauges will add info. but this should get you started.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 03-30-2008, 08:52 AM
I just bought a dozen. They're cheap, you can replace all at the same time for even lighting, and have a spare or two....
1984 928s
5 speed
Old 03-30-2008, 02:09 PM
dshepp806's Avatar
Yep,..spares are good....
Best,
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 03-30-2008, 03:54 PM
Thers also the bulbs for the ventilation control, ashtray, fog light switch, heating control between the seats , glove box and while you're at it replace the interior bulbs as well. Might as well do the lot plus it'll give you a chance to clean the contacts
'83 SC Coupe
Old 03-30-2008, 04:25 PM
