Odd buzzing noise from rear of car
This started a little while ago, and happens randomly. Not very often, and it doesn't matter whether I'm braking, accelerating, or idling.
Coming from the rear, it sounds like it's on the passenger side of the car, somewhere under the rear deck. At first, I thought I'd blown a speaker...but no. It sounds much like a cell phone on ultra powerful vibrate under the rear deck or something. Gets slightly higher in pitch, and then dies. Only last for a few seconds. It's always the same. Engine speed does not matter. What could cause this intermittent, random noise from that area of the car?
'85 911. White - 53,000 miles bought 3-16-07. "Casper" '88 924S. Blue - 120k miles bought with 105k miles. '94 968 Coupe - White - 108,000 miles bought 9-28-17 '09 Cayman - Grey - bought 9-8-20 |
Member 911 Anonymous
AAV (Ambient Air Valve), engine compartment passanger side under lid arm next to the oil filer neck.
It will look like a wide bell shaped plastic part with 3 hoses coming out of it (one out of the top another toward the front of the engine and then other to the oil filler neck) held by a brass bracket. If it has been updated, it will be a metal flying saucer part about 3" in diameter and inch tall, two hoses toward the front and one to the oil filler neck. I bet it only makes that noise when your baby is cold or cold mornings, huh? Hope this helps
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
engine bay buzzing noise
And I'll bet it sounds like a kazoo and it only happens when it's cold.
O2 In Sully We Believe |
Going to take the car out today to pick up oil..we'll see how many times it happens.
Cold outside, not cold engine
'84 911, some sort of red color '05 Subaru WRX wagon |
If you have auto-heat it could also be the flappers adjusting themselves. I hear mine every so often, but they are not very loud.
madmmac AKA Mitch 1984 Factory Turbo Look 2006 4Runner 1998 TRD Supercharged 4Runner (Sleeper) |
I'm thinking it's got to be the subject in the post linked above.
it's a stretch, but I just got my car out of hibernation, and the heater fan was causing a racket. More of a squeal than a buzz, but it's worth a thought.
89 Carrera 3.4 "There is a right way to go around a corner - it's called the line." -- PCA DE speaker bryteside.com - good things happen. |
Wow. I always wondered what that noise was. I haven't heard it in a while, but you definitely described it perfectly. Thanks for the answer, Draco and Mark.
This is making me rethink an odd noise I've had on my 964 latley... similiar, but higher pitched... hmmm, something to think about anyway, and I bet I do have auto-heat...
-Andy '67 912, '92 C2, and '93 RSA - all gone
probaly that plastic valve just in front of the oil filler cap.
