crashr's Avatar
Oil Restrictor Question
Hi Folks,
I am dealing with a hunting idle issue on my 2.7 to 3.2 Conversion engine. I went and saw the local Porsche wrench today and he mentioned a few things. The first was he said it must be running rich. I told him that I leaned out the mixture already but it is still hunting (not as badly though).
He then asked whether I installed an oil restrictor when I did the 1987 3.2L Engine in my 1975 car. I had no idea what he was referring to? Can someone comment on whether I missed something when I was doing my conversion? What is an oil tank restrictor? I have read the article about the oil restrictors for the camshaft but I don't believe this is what he was reffering to.
Lastly, would the lack of this oil tank restrictor cause a hunting idle?
Thanks,
1975 Widebody 911 3.2 Euro
Old 07-31-2009, 01:51 PM
dshepp806's Avatar
maybe the oil "line" restrictor"? Many have seen the results of cut off when the oil cap is removed (a symptom..). Not sure about it's relation to "hunting issues"...idle=yes.
Have you the Bentley? It shows where it is within the rubber oil line (up top).
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 07-31-2009, 02:32 PM
Bill Verburg's Avatar
de je vue all over again
Bill Verburg
Old 07-31-2009, 02:33 PM
Throw it on the ground!
Part # and picture here:
Motor dies when I open tank to check oil
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 07-31-2009, 04:38 PM
muck-raker
kidrock's Avatar
a bad O2 sensor will cause hunting too...if you installed one during the conversion.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 07-31-2009, 06:11 PM
crashr's Avatar
No 02 sensor, as it is a euro engine.
Old 07-31-2009, 06:17 PM
crashr's Avatar
I checked my oil breather hose and I do have the reducer in the oil line. Guess that wasn't my issue.
Old 08-02-2009, 01:31 PM
rsscotty's Avatar
I have seen this when the idle screw is turned out too far. The base idle should be around 800 rpm.
Old 08-02-2009, 01:37 PM
Originally Posted by crashr View Post
Hi Folks,
I told him that I leaned out the mixture already but it is still hunting (not as badly though).,
Keep leaning it further. You're not there yet. If you leave the oil cap off, a quick way to add leanness, I bet the hunting stops.
Old 08-03-2009, 06:05 AM
