carreraken's Avatar
Cam Tower Line - 3.2 left side
I have this replacement left side cam tower oil line, but the middle connector is way off (about an inch)... Is this how they are? I don't like to 'force' things because I tend to break things when I try...
Try to fit this???
Ken
06 Cayman S - gone
85 911 Targa - gone back home to Germany
73.5 911T Targa - long gone...
Founder ncPOG: nevada county Porsche Owners Group - disbanded post covid after 15 yrs
Old 04-19-2008, 11:15 PM
Member 911 Anonymous
DRACO A5OG's Avatar
That just doesn't look right, can you compare to another known correct one? Where may I ask did you get them?
BTW, when I did a recent PPI, wrench stated I had Cam Tower Leaks at #'s 5 & 6. Do you think they were referring to this type of lines?
'85 Carrera Targa
PCA/POC
Old 04-20-2008, 12:07 AM
slodave's Avatar
Can you attempt to 'fit' without getting it dirty. It does look weird, but its hard to tell if they are the same length or not. You can bend the middle line a little. When I took mine off, I was caeful not to bend them, but I had a hard time getting (I believe) getting the left one back on. I tweaked it slightly, but made sure not to crimp the thin line.
Old 04-20-2008, 12:24 AM
3.2 CAB's Avatar
What is the part# on that line? I have a new left side here somewhere. I will see if I can find it and see if it looks like the one you are showing. Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 04-20-2008, 07:20 AM
the steel line has been updated to match the new style cam line. you can tweek the old one to fit if necessary.
206 637 4071
Old 04-20-2008, 08:15 AM
carreraken's Avatar
Draco, I go these from perf. products about 3 yrs ago, maybe that's where I went wrong..
Slodave, I don't think I can try fitting without the part getting marked up. The line to the center connector can 'maybe' be bent to match the new location, but I would have to remove the factory plug wire holder to make it work... but then again, I don't want to 'pinch' the line or break it....
(edit) The overall length looks good, it's just the middle connector. It will also sit closer to the engine than the original...
3.2Cab, the part number is: 930-107-347-05-M20
I went ahead and ordered a new one from our host... we'll see how it looks...
Ken
06 Cayman S - gone
Old 04-20-2008, 04:31 PM
carreraken's Avatar
Thanks John, took me a while to figure this out.
ken
Ken
06 Cayman S - gone
Old 04-24-2008, 01:16 PM
