Less brakes, more gas!
*sigh* so I've been building my motor over the last 2+ years and I'm getting to the final stretches. I've been very patient and waited and waited... and waited some more to pick off the right components when they came up on the classifieds or eBay. I collected some header extensions already ceramic coated... a year later I got some short headers. They were rusty, but totally usable. Then the cool twin pipe sport muffler showed up and I was on it like a good rubber undercoating (if you have ever tried to remove this stuff you will know what I mean) Followed by the right oil lines last month and I had my kick ass system ready to wake the neighbors!!
I finished my long block last week: Engine story w/ pics Tonight, I figured I'll test fit the exhaust as I'm awaiting my oil cooler from the cleaners and snap a few sweet pics for the board. I started with the engine mount bar and the plate for the muffler straps. Cake... and all that powder coating is lookin' goooood! Then I slap on the freshly ceramic coated headers. I think to myself, "I hope they stay shiny for a long time! Then the header extensions go on after some diggin' through my HW stash for some bolts that would work well. One side looks a little off, but I'm not thinking it will matter much. so I put the Muffler on the funny side thinking I could get more leverage to fit it up to the other side... Things that make ya go Hrmnnnnnn..... ![]() ![]() And ![]() It is not even close... about 6" off... *scratch head* Looks like my muffler is too short or the headers are too wide or a little of both. Possibilities:
Best regards, Michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
The problem does not appear to be with the headers or the muffler, it appears to be with the connecting pipe on the right of your pic...
Althought he pipes should be symetical, have you tried swapping the connection pipes side to side? Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 Last edited by Jeff Alton; 04-25-2008 at 09:42 PM.. |
winter
agreed, check the pipes first. If that doesn't sort it out, then SCREAM, and then find a muffler shop that can fab a connecting section of pipe for you.
Good luck. --- Tom |
It looks like the connector pipes are the issue. I can't tell from the pictures if those are supposed to be symmetrical or asymmetrical. Something about the way the connector pipes appear in the pics. Are the tubes the same overall length from flange to flange? Are the two bends towards the flanges the length? Is the middle straight section the same on both pipes. I think you will have to fiddle with them and have everything pointing in the right direction. Engine turned bottom down. Good luck!! Tony.
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
Huh?
The driver's side header is tweaked. Notice how the passenger side header exit is right below the valve cover and the driver's side isn't?
'84 911, some sort of red color '05 Subaru WRX wagon |
Passenger side exhaust exit position looks pretty close to normal (left side in photo).
On closer examination, the exh. flange of the driver's side header (right side) is further away from the engine than the passenger side. That's where the problem is. It might be that the skewed header might be a prototype unit gone astray or possibly one designed to accommodate a turbo. I notice these pieces are from different sources so there might not be any vendor recourse here. If you install the muffler centered onto the muffler bracket with the 2 straps, you'll have a better idea of where the exhaust flanges have to be. 6" is a lot to make up, but that's "only" 3" per side. Sherwood |
Dog-faced pony soldier
Just lose the muffler and run megaphones.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
Not Quite Banned
Bolt up the muffler on the left side and I think you will see the angles and position look more correct.
The problem appears, as already mentioned, to be the right side (or drivers side) header. Regards -
Thomas Owen 1972 911T 1972 911S |
You need to straighten the header or Fab a new connector. Header must have come from a car that was pranged in the rear.
Now the question is, if you fab the connector, is the header going to give you clearance issues when you want to install the engine ? My assumption is no, but when I assume, it usually comes back to bite me later. |
I dunno might just be angle of the pictures for the right side header.
You can get another set of used cheapie headers for <$200 to get you on the road and change the exhaust to a piece of art later.??? Or new extensions would be cheap solution.
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
Senior Member
As Thomas says, bolt the muffler up to the left side and it will be pretty much centered. Then you will see how far off the right side piping is. When you can take a photo with the camera lower and facing straight back towards the headers and lined up with the engine case seam. This will really show how far out of kilter the right side (drivers side) headers are. Joe
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
UnRegistered User
You could try to slot your flange bolt holes to allow some adjustment on the header to connecting pipe and also to the muffler.
Could you lag or bolt the right side header to an old solid core door and put a pipe inside the collector that fits snug and tweak the header back to where it needs to go? Don't think I would try it on the engine, but it might be ok..
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
+1 the header is tweeked on the right side. The muffler will never line up to the car's centerline until the header is bent back into the proper position. It doesn't seem like it would be too much of a problem to tweek it back to the proper position.
1979 911SC 3.2 SS Custom Backdate Hot Rod 1972 911T, 2.7RS Spec Beck 904 Carrera GTS /3.6 2023. Macan Previously owned several 911 models since 1975. |
Crotchety Old Bastard
Those headers are WAAAAY off. Who is the manufacturer?
I would wait until the engine is back in the car. Strap the muffler in its mount, line up the tailpipes where you want them to exit, THEN cut/reweld the connection pipes to make it all line up perfect. Attempting to bend the collector back to where it should be could damage the heads or, if the header is removed, cause the primaries to not line up. My opinion.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 Last edited by RarlyL8; 04-26-2008 at 06:40 AM.. |
Senior Member
Also, take a tape measure and measure from the center of the crankcase seam to the collector on the left side. Then do the same on the right side.
Bet you find 3-4 inches minimum difference and thats where your split is. This measurement should be equal on both sides, period.
The header on the drivers side is definitely tweaked. But, are we sure they are supposed to be centered on the engine? It would make sense, but this is my first set of headers so I submit to the general wisdom.
The extension pipes are symmetrical. Even if the header was no tweaked I think the connections on the muffler would be too narrow. I'll experiment tonight and provide more pics/measurements. Best regards, Michael
7.0:1 > 11.3:1 > 7.0:1
Any chance the seller will still give you a refund which you can put toward some good units? |
Wow Michael, your project is coming together nicely...your motor is a work of art!
![]() Hmmmm.....I'm scratching my head becasue on my 3.0L application, that muffler bolted up to my SSI's perfectly.....those 2 inlets are at the stock position. |
Band.
Gimme a hammer. I'll fix it!
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
I have a 'sprung' exhaust
hehehee good thoughts guys!
I have a lot of hammers already (some of them really big too) there will be no 'vendor' recourse here. Everything was private party purchase and I think those headers have been under my car for over a year anyway. Well, after some good advice and some thinking... I pulled out the strap winches... Can I drive this way?? ![]() After the winches are loosened everything stays almost centered. there is about a 0.75" difference as best I can tell: ![]() The whole thing is under some strong compression. That is some concern to me, but I think it will be ok. I'll just have to remember that when I go to take it all off I better bring out the straps again. Those headers did NOT want to bend. I am pretty sure that they merely moved and did not actually get into the plastic stage so they will bounce back to where they were before when it all comes apart again. Concerns?? BUT, now I have a new problem. The gap between the muffler and the plate that the muffler straps go around is about 2"+. Do you think it will still fit in the car?: ![]() I'm thinking of welding up a bracket to support it... somewhere... Ideas?? Best regards, Michael
