930 Trailing Arms
Searching through various threads on the subject:
I understand that to install late 930 trailing arms on a narrow body (72 c/w turbo flares) using the correct offset mounts, then the hub will end up moving approx 1" (25mm) to the outside. Does this mean that a standard 11" Fuchs cannot be used? Thx Martin |
HI martin
with STD turbo arches , yes 11" wheel will not fit under. regards mike
Regards mike 1983 911 SC sport, 1982 mini city |
HI Martin
try contacting neil from the site below, he may know or have some split rim 11 x 15" Fuchs from some track cars he has, with the correct offset. http://www.bsmotorsport.co.uk/ regards mike
Friends of Warren
Martin
Jeff Alton is finishing up his forged Fuchs replica wheel. He will do a 15 AND a 17 in model. You'll be able to specify sizes and offset. As per the timing.... I have no idea. |
