i'm just a cook
onlycafe's Avatar
what the hell is this noise?
I just got my '79 911sc back from a full paint job with bodywork and it has developed a rather troubling engine noise. I think I know what valves sound like, and I don't believe these are its cause. It is a marbley, inconsistent rattling emanating from the bottom side of the engine that seems to occur primarily at low idle, though it simply may be more apparent in the relative quiet of 800 rpms. There isn't much more to it than that. Tech books suggest timing chain issues or cam bearings. To me it sounds a lot like the bent pushrod issue I dealt with in a 1967 Corvair. (The Corvair ran $400 for a fix; God only knows for a P-car.) Does anyone have a clue as to the source of my pain?? Any input would be greatly appreciated. I'm considering simply turning up the idle and keeping my fingers crossed.
Old 04-29-2008, 09:46 AM
sudo apt-get purge 930
equality72521's Avatar
Well it certainly won't be push rods I vote for tensioners.
--clutch-monkey
Old 04-29-2008, 09:59 AM
Max Sluiter
Flieger's Avatar
sounds like a collapsed cam timing chain tensioner. What kind you got? Carrera updated pressure fed? 930 sealed? do you have safety collars?
Old 04-29-2008, 10:00 AM
nreed's Avatar
Intermediate shaft backlash? Does it go away if the idle increases?
Norm '86 930
AEM Infinity 6 - Twin Plug 3.6L - DBW - JE Pistons/LN Eng. Cylinders - Pauter rods - GT3 Crank - GTX3584RS - ID1050x Injectors - Ported Intakes - Custom Intake Manifold, exhaust and intercooler - 993SS cams - ECUMASTER PMU-16DL
HRE Wheels 560R 8.5x18 ET25 (Front) 11x18 ET0 (Rear)
Old 04-29-2008, 10:17 AM
