Anyone modified an old CAT
1) Can you disable an old CAT without any negative impact?
2) Is there any significant noise impact when replacing CAT with by-pass pipes? Thanks, Dan |
sudo apt-get purge 930
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
I'm a loser, baby.
I just did that. The difference in weight (Bursch bypass) is about 7lbs. I did notice a bit more torque around 3500rpm with the bypass and stock muffler. Sound was basically the same. Check the thread from the previous post for feedback with a cat/muffler bypass setup that I will be finishing tomorrow. Looking for my earplugs now.
You could have the old cat punched out too. Basically the same as the bypass without the weight loss I would think.
1979 911 SC |
Really? Taking off a Cat typically reduces torque because you lose "good" backpressure.
I'm a loser, baby.
I think with the stock heat exchangers, which are supposed to be the more restrictive part of the exhaust system there is back pressure. Again, I am no expert.
1979 911 SC |
Southern Class & Sass
If your old cat is plugged, you can empty it out. The interior is three ceramic "bricks". All you need is a steel rod, a hammer, a vacuum, and time.
If your cat is good, you'd be better served to buy a bypass pipe and save your converter for reinstallation later.
Dixie Bradenton, FL 2013 Camaro ZL1 |
