HawgRyder's Avatar
Send a message via ICQ to HawgRyder
We used to use Castrol 20/50 in the racing VW engines...with Wynn's Friction Proofing in the oil.
BUT...we needed to run in the rings before adding the Wynns!
We found that if added too early...the rings would not seat.
So...I guess what I am saying is that the stuff worked...it reduced friction...but the engines got torn down more than 2 or 3 times during the season.
For what it's worth.
Bob
Bob Hutson
Old 03-13-2013, 08:12 PM
AutoBahned
RWebb's Avatar
barndoor - when you drive back from PDX, drop off a vat or so of the Brad Penn here in Eugene
Old 03-13-2013, 08:30 PM
Good information, but I still feel like whatever oil I choose will always be inadequate in some way. For example, there's talk about catalytic converters, which BTW have been installed on US cars since 1974. What level of zddp is appropriate for a late 70's 911 if you need to take the catalytic converter into account?
The paper says CI-4 oils are best, those are intended for diesel engines right? What about something like Valvoline All Fleet Plus? It seems to have the right amounts of zddp but the MSDS I found says something about paraffinated something or other. Does that mean it's a "bad" Group I oil?
I'm so confused.......
Hugo
Present: 1984 928S/Indischrot, 1994 968/Polar Silver
Past: 1979 911SC Targa/Petrol Blue
Old 03-14-2013, 04:08 AM
AutoBahned
RWebb's Avatar
true - whatever oil you choose will always be inadequate in some way; I suggest rebuilding your SC and later engines every 300,000 miles even if they do not need it
Old 03-14-2013, 11:09 AM
richardlw's Avatar
Hugo
Yes, Catalytic converters have been on cars to some extent for a lot of years, but I believe (this I can't say for sure) they were less efficient and less sensitive.
What I can tell you is that I use CI-4 Synthetic in my 88 BMW and so far the converter is not blocked. I have no way of measuring if it is effective, but since I use 28% leaded av gas in it, I doubt it. (gasoline here is 80 octane, although every couple of months one gas station brings in a load of 90)
The problem with the phosphorous comes not merely from the level, but what they learned after the SM fiasco was that some phos compounds evaporate more readily. So the SN oils have to maintain 79% of their original value. The better CI-4's and CJ-4's are made with the better phos compounds, so you could have 10% evaporation of 1200 ppm in a CJ-4 and still have less contamination than the 79% retention (21% evaporation) permitted in an SN with it's 800 ppm limit.
Taking care of Cars and Industry in Bolivia
Richard's Corvair
Selection of the Right Motor oil for the Corvair
Old 03-14-2013, 05:04 PM
Dial 911
A horse with no name's Avatar
Mobil 1
Hi...For what it's worth - I use Mobil1 synthetic 15-50. If I drove the car during the winter I would likely go 10-40.
Cheers!
“Simplicity is the ultimate sophistication.”
Leonardo Da Vinci
Old 03-14-2013, 10:04 PM
HarryD's Avatar
Richard:
School me. What is the "SM Fiasco"?
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 03-15-2013, 07:26 PM
RETIRED
Joe Bob's Avatar
Lead kills cats, you burn unleaded gas. Burning oil shouldn't be an issue, if you are burning enuff to clog a cat, that cat is the least of your worries.
2012 ML350 3.0 Turbo Diesel
Old 03-15-2013, 07:37 PM
Are we still going with the same brands over a decade later? Have they been bought out or changed ownership or changed philosophies on quality? Maybe they decided to change their formulations to something cheaper to pay off some bills? Maybe regulations in the last decade have forced them to formulate oil differently. Has anyone checked this out recently?
Old 07-25-2019, 10:06 PM
Bill Verburg's Avatar
There have definitely been formulation changes in some oils over the last 10 yrs.
LN Engineering puts out an informative series of updates on this topic
here is the latest detailing changes in Brad Penn and VR1
LN is recommending the newest line of Driven oils, specifically Driven GP-1 20w-50 or 15w-40 for the aircooled cars
I see no change in M1 15w-50 and will continue to use it in my cars.
Bill Verburg
Old 07-26-2019, 09:55 AM
Dial 911
Thumbs up
‘Dido’...Mobil1 15-50 continues to work very well for our 3.2
Cheers!
Leonardo Da Vinci
Old 07-26-2019, 11:17 AM
I moved from Brad-Penn to Liqui Moly Touring High Tech 20w50 and could not be happier. Much lower oil consumption and smoother idle. I also add two 300mL cans of Liqui Moly MoS2 (molybdenum) to protect moving surfaces, including tappets; being a solid lubricant it adheres to the surface and protects cold starts.
Eine Garage ohne Porsche 911 ist nur ein dunkles Loch - Walter Röhrl
Old 07-26-2019, 12:29 PM
Protective zinc and phosphorous only apply to flat tappet engines, mostly vintage cars that don't have roller cam followers.
The short answer is to stick with the oils mostly recommended here.
As mentioned above, it's not as simple as buying oil w/zinc/phosphorous or adding it to regular oil as an additive. Manufacturers are on the band wagon touting their own Zinc/Phosphorous claims. However, only oil manufacturers can improve the quality of the base oil/additive package (i.e. customers cannot make chicken soup out of chicken ____).
The long answer is here. It's a little dated (2013) and manufacturers have had time to reformulate. It's a good read, but long, like the Mueller report. Also, good engine tech tips buried in the tome:
https://540ratblog.wordpress.com/
synthetic-oil-not-20w-50-a.html
Sherwood
Old 07-26-2019, 12:57 PM
