Engine quit
I drove my 1986 911 600 miles in one day at a pretty fast speed last week, not a single problem. Once at my destination I was driving around and my engine just quit cold turkey. It failed to restart inmidiately, I waited 10 minutes and it fired right up, it did it 3 more times before the day was over. The next day I start my trip back and before the first 100 miles it quit twice, same thing, the next 500 miles averaging 80 mph not a problem. Any ideas, fuel pump, fuel filter? Thanks
86' 911 Coupe |
First (and easiest) place to start is the DME relay. It's under the driver's seat and is easy to replace. The general rule of thumb is that the question isn't "if" the DME relay is going to fail...rather, the question is "when?" It sounds like if yours is bad, it's an intermittent problem. I replaced mine before it failed, and keep the old one in the glove box as an emergency spare.
Our host sells them for $30.50. Part number 911-618-154-00-M252. Good luck!
1984 Targa |
Are DME relays known for intermittent failure? Could be a loose wire to one of the flywheel sensors, too.
I had the identical symptoms with my 1988 3.2 liter car. (And I mean identical. I could have written your post.)
Turned out to be a defective temperature sensor. This was replaced for about $100.- (Porsche part # 930 606 915 00) - and I never had the problem again.
_____________________ These are my principles. If you don't like them, I have others.—Groucho Marx |
Man, this is getting confusing. The entire time it was cool weather, temperature gauge was a little below the first mark. Actually when it failed was late afternoon and early morning, it was cool and damp. On the way back the day got hotter, I ended up running the AC the last 300 miles. Is there anyway to test a relay?
86' 911 Coupe |
Sure... but it is hard to find an intermittent failure.
http://www.911chips.com/dmerelay.html What color is your coupe? If I see you on the side of the road dead I'll stop and help.
Rick 88 Cab |
Un Chien Andalusia
I replied to your other post in off-topic but I might as well copy it here.
I second the DME relay. Even if you get one and it isn't that I assure you that you will want one to carry around in the glovebox. The DME realy has this habit of quitting at the most inappropriate time and it's so convenient if you can just swap it out. That said it could well be something entirely different but most intermittent or sudden failures like that seem to be DME relays.
2002 996 Carrera - Seal Grey (Daily Driver / Track Car) 1964 Morris Mini - Former Finnish Rally Car 1987 911 Carrera Coupe - Carmine Red - SOLD :-( 1998 986 Boxster - Black - SOLD 1984 944 - Red - SOLD |
Un Chien Andalusia
This is the temperature sensor Dottore was talking about, NOT the one for the gauge. Sorry if you knew this already, but I by reading your post I didn't think you did.
+1 with Aerkuld and the others. it could be several things that "could" cause the type of problem that you describe:
CHT Sensor DME Relay DME Control Unit Reference Sensors Fuel Relay/Pump/Filter Crap in fuel tank clogging filter Somewhat of a broad based problem, with a possibility of one or more contributing factors. Good luck with the testing!! Tony.
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
I did not know this, thanks for the good advice.
86' 911 Coupe |
I too could have written your post a month or so again. I researched this to death and got extensive lists like you have gotten above. Ultimately I swapped out the DME relay first as has been suggested and have never had a problem since. Threw the old one in the glovebox only until I got another new one to replace it. I wanted a known good spare. The relay I pulled was the original with the 1986 date stamp, but after being stuck on I-95, better to be safe than sorry.
Steve 58 356 Speedster 70 911S Targa, 73 914 2.0, 73 911RS Targa 05 Boxster,23 Macan T |
My DME relay was nice enough to warn me a few times before it was replaced. It was the original relay. For the cost just replace it and buy a spare for the glove box. If it is not the problem right now it will be a problem in the future if you still have the original relay.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Un Chien Andalusia
Pipo - please let us know if you fixed this and what it took. I tried to PM you but it appears that you aren't set up to receive them.
I ordered the relay from the host. However, the car starts and run so I will not know for sure if that was the problem.
86' 911 Coupe |
You shoud compare notes in a couple of weeks with
1988 911 stops dead this one got fixed 1987 Targa no spark and this from SW Carrera stalling problem ... can you spot the problem?
Rick 88 Cab |
Thanks for the reference, boy I have a lot to learhn about this car, VW were so easy...
![]() Quote:
86' 911 Coupe |
Damned right "safe than sorry" !!!!!!!!!!!!!! Have another brand new one in the glovebox, keeping the original in the bonnet stock. Best,
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
I replaced the DME relay and the temperature sensor. The car ran for a while and now is quitting again. This time start with difficulty the reps goes up and down until it shuts off.
86' 911 Coupe |
Thread Tools | |
Rate This Thread | |
