IAN
Guest
Posts: n/a
Post Stalling at 50mph, any suggestions?
Last weekend my 72 911T stalled twice, while travelling at around 50mph. It was a smooth stall that lasted only a second or two. The engine then started right back up, back fired once and then ran as usual.
This also happened once at idle as well.
It is a 2.4 motor with MFI.
Any suggestions? Bad gas? MFI problems? Electrical? All of the above?
Thanks.
Old 05-29-2001, 08:23 AM
jabb
Guest
Posts: n/a
Post
I would check the fuel filter.. and electrical connections to the fuel pump.
  • Joe A.
  • 84 911 Targa
  • 75 914/6 3.0
Old 05-29-2001, 08:56 AM
IAN
Guest
Posts: n/a
Post
Where/what would be the most likely connections to check? The more I think about it the more electrical is seemed.
Old 05-29-2001, 09:03 AM
Jens Wendorff
Guest
Posts: n/a
Post
I would start checking the relay/relay contacts and the fuse panel.
Then check the electrical connections at the fuel pump itself. Maybe a crimp is loose/detoriated.
Jens
Old 05-29-2001, 09:36 AM
